查看: 2453|回复: 0
[供应] Wallys/QCN9074 11ax 4x4 MU-MIMO 2.4G M.2 /2.4GHz, max 23dBm per chain, up to ...
签到总天数:8天
签到总奖励:36金币
发表于 2022-10-27 15:21:33 | 显示全部楼层 |阅读模式
QCN9074 11ax 4x4 MU-MIMO 2.4G M.2 /2.4GHz, max 23dBm per chain, up to 1147Mbps //QCN9072/QCN9024
Wallys could help clients build Prototype. We have a professional technical team supporting. Helping you realize your idea is our aspiration. Everything on RF is our enthusiasm. Different chipsets, different materials, different features, different designs...we could realize all you want. Making your idea visible and alive is what we persuit
We work exclusively with certified labs and also perform testing in-house, covering a wide range of certifications and standard, including FCC,CE and etc. Our lab testing solution provides exhaustive due diligence to limit your company’s risk for liability and ensure that product meet all legal and safety requirement
● OEM Since its inception in 2010, Wallys has had a strong team, including dozens of research and development personnel, a complete set of assembly lines, they play an irreplaceable role.Under the premise of ensuring the product quality, we will deliver the goods at the fastest speed and maximize the product benefit. ● ODM China has a complete wireless communication industry group, which enables ODM manufacturers to obtain the supply of low-cost components. Years of reform and opening-up have made China an ideal low-cost manufacturing base. Compared with the rapid development of the market, ODM services which focus more on design capability and production experience become more competitive
BY:Wallys Communications (Suzhou ) Co., LTD
1. DR9074-2.4G(PN01.1)
https://www.wallystech.com/Network_Card/DR9074-2.4G-PN01.1-Wifi-6-Qualcomm-QCN9074-Single-Band-2.4-GHz-4T4R-M.2-E-Key-Interface-802.11ax.html
Features
■ Qualcomm Atheros QCN9074
■ 2.4GHz, max 23dBm per chain, up to 1147Mbps
■ Single Band 2.4GHz 4x4 WiFi 6 (802.11ax
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ PCI Express 3.0 Interface
Absolute Maximum Rating
Parameter
Rating
Unit
Operating Temperature Range
-20 to 70
ºC
Storage Temperature Range
-40 to 90
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
Chipset
WLAN Host Interface
System Memory
2Mbit serial I²C bus EEPROM
Standard Operating Voltage
5V
Operating Systems
QSDK
Host Interface
M.2 E Key
Antenna Cable / Port
4 x MMCX Connectors,4T4R
Frequency Range
2.412GHz-2.472GHz
Data Rates for WALN
2.4GHz, max 23dBm per chain, up to 1147 Mbps
Channel Spectrum Widths for WLAN
Support 20/40MHz at 2.4GHz
Modulation Techniques
OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM
Temperature Range
Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity
Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification
TBD
Power Consumption
TBD
Reference Design
PN01.1
Dimensions (WxHxD)
57mm x 63mm x 6mm
2. DRC-AP5159
https://www.wallystech.com/Industrial_Wireless_AP/DRC-AP5159-Wireless-Access-Point-5GHz-outdoor-PTP-PMP-long-distance-UV-protected.html
https://www.youtube.com/watch?v=7ww5CD9TAsQ
Features
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 6.1GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
19dbi 5GHz/16dbi 2.4GHz antenna (optional)
GMT+8, 2026-10-23 20:58 , Processed in 0.021643 second(s), 10 queries , Gzip On, Redis On.
