查看: 3988|回复: 0
[供应] Wallys WIFI6 4X4 M.2 Module|QCN9074 QCN9024 What is the difference?
发表于 2023-6-21 11:59:33 | 显示全部楼层 |阅读模式
Qualcomm QCN9074 and QCN9024 are two powerful wireless chips that have been widely used in various network devices. With their advanced features and capabilities, they have become the top choices for many manufacturers and users in the industry.
Qualcomm QCN9074 and QCN9024 are two of the most popular wireless network cards on the market today. Both offer similar features, but there are some differences that set them apart. In this article, we will compare the key features of these two network cards to help you decide which one is right for your needs.
Frequency Bands: Both QCN9074 and QCN9024 support 2.4/5/6 GHz frequency bands, making them ideal for use in a variety of wireless applications.
Antenna Configuration: Both network cards feature 4x4 MIMO antenna configuration, which provides improved signal quality and reduces interference.
Frequency Range: QCN9074 supports a wider frequency range of 4.9 GHz to 7.125 GHz, while QCN9024 supports a narrower range of 5.150 GHz to 7.125 GHz.
Full Band Support: Both QCN9074 and QCN9024 support 2.4Ghz, 5Ghz, and 6Ghz full band, providing flexibility for various applications.
4.9Ghz Support: QCN9074 supports 4.9Ghz, while QCN9024 does not support this frequency range.
Operating Mode: Both network cards support AP&Client operating mode, which allows them to function as both access points and clients.
Maximum Connected Clients: QCN9074 supports up to 512 maximum connected clients, while QCN9024 supports up to 256 maximum connected clients.
MU-OFDMA DL/UL: QCN9074 supports up to 37 users per PPDU, while QCN9024 supports up to 16 users per PPDU.
Both Qualcomm QCN9074 and QCN9024 offer similar features and are suitable for a variety of wireless applications. The main differences between the two are the frequency range and maximum connected clients supported. If you require support for 4.9Ghz or need to connect more than 256 clients, then QCN9074 would be the better choice. However, if these features are not essential to your needs, then QCN9024 may be a more cost-effective option.
One example of a network device that utilizes these powerful chips is the Wallys DR9074-5G and DR9074-6E network cards. These network cards are designed for high-speed wireless connectivity in enterprise environments and feature the Qualcomm QCN9074 and QCN9024 chips, respectively.
The DR9074-6E network card boasts support for the Wi-Fi 6E standard and operates on the 6GHz frequency band, making it a suitable choice for devices that require high-speed and low-latency wireless communication. The 6GHz frequency band is relatively free of congestion, enabling optimal performance with minimal interference.
On the other hand, the DR9074-5G supports the Wi-Fi 6 standard and operates on the 5GHz frequency band. It is a good fit for devices that require reliable and fast wireless communication. However, due to the popularity and widespread use of the 5GHz frequency band, it may be more vulnerable to interference.
Datasheet are available to download from the website of the product.
DR9074-6E
DR9074-5G
Both the DR9074-5G and DR9074-6E network cards are compatible with a range of operating systems, including Linux and Ubuntu, and come with a variety of advanced features, including WPA3 encryption, IEEE 802.11ax support, and advanced QoS capabilities. These features and capabilities make the Wallys DR9074-5G and DR9074-6E network cards ideal choices for industrial and IoT applications that require high-speed, low-latency wireless connectivity.
Wallys Communications(Suzhou) Co.,Ltd,known as a specialist in researching and developing and producing of wireless communication products,have star product as Routerboard,Network Card,Industrial Wireless AP,Antenna etc,is one of the suppliers of the Facebook.
With the professional R&D teams which possess over 16 years experience,we could not only providing OEM/ODM/JDM services,but also have the ability to supporting customization service for you.From idea design to manufacture to put the product into market.
If you are interested in learning more about the Wallys DR9074-5G and DR9074-6E network cards, you can visit their website at https://www.wallystech.com/ or contact wallysteam via sales1@wallystech.com.
GMT+8, 2026-11-3 03:46 , Processed in 0.021728 second(s), 10 queries , Gzip On, Redis On.
