查看: 1513|回复: 0
[供应] IPQ9574 and QCN9274: Explore the WiFi7 MLO feature Test with Wallys DR9274
发表于 2024-1-4 09:37:00 | 显示全部楼层 |阅读模式
MLO enhances the efficiency of channel usage for both Access Points (#AP) and clients, allowing for the simultaneous transmission of data across multiple channels. Whether we are streaming videos, making video calls, or simply browsing the internet, our reliance on fast and reliable wireless connections is crucial. However, when multiple devices compete for limited bandwidth, causing congestion and reducing performance, Multi-Link Operation (MLO) emerges as a potential solution.
MLO is a feature that empowers Wi-Fi Access Points (APs) and clients to transmit and receive data across multiple channels or frequencies simultaneously. Its primary goals are to reduce latency during network congestion and increase overall throughput by aggregating multiple links.
IPQ9574: Known for its high-performance capabilities, the IPQ9574 SoC from Qualcomm Technologies is a crucial player in enabling robust and efficient networking solutions. With its advanced features, it sets the stage for the implementation of MLO, contributing to enhanced channel utilization and improved network performance.
QCN9274: As another integral component in this exploration, the QCN9274 complements the IPQ9574 with its Wi-Fi connectivity prowess. Together, they form a dynamic duo, amplifying the effectiveness of MLO and ensuring a seamless and reliable wireless experience.
Wallys Solution:
DR9574+DR9274
Qualcomm IPQ9574 Quad-Core ARM-A73 @2.2GHz processor. l
Qualcomm Atheros IPQ9574 for Industrial Grade;l
4x4 on-board 2.4GHz radio, up to 1182Mbpsphysical data rate;l
Flexible Wi-Fi 6E/Wi-Fi 7 radio configurations via4x M.2 (NGFF) E Key Socket with PCIe 3.0;l
4x 1Gbps ethernet port, 2x 10Gbps ethernet port;l
1x USB 3.0 port;
DR9574 based on IPQ9574 Chipset is an enterprise wireless router board integrated with 4x4 MU-MIMO Wireless Module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment.
DR9274-6G
Features
Qualcomm Atheros QCN9274 for Industrial Grade;
Maxim Tx power 22dBm per chain;
4x4  6G MU-MIMO, up to 11530Mbps physical data rate;
Support up to 4096-QAM;
M.2 connector;
PCI Express 3 .0 Interface
DR9274-5G
Maxim Tx power 20dBm per chain;
4x 4 5G MU-MIMO, up to 5765Mbps physical data rate;
M.2 connector;
MLO configure
After configuration, you can establish a connection with MLO through the serial port.
Contact us
For inquiries or to discuss your specific requirements, please contact our dedicated sales team at sales1@wallystech.com
GMT+8, 2026-11-3 04:35 , Processed in 0.026433 second(s), 8 queries , Gzip On, Redis On.
