查看: 928|回复: 0
[供应] IPQ5018 vs. IPQ4019: Why Industrial WiFi Needs a Performance Boost
发表于 2025-2-6 13:22:01 | 显示全部楼层 |阅读模式
WIFI 7 IS HERE, ARE YOU STILL STUCK WITH WIFI 5?
With the rapid evolution of wireless communication, industries relying on stable and high-performance connectivity must stay ahead. If you're still using WiFi 5 solutions, it's time to explore the new generation of industrial networking with Wallys' DR5018S router board powered by IPQ5018/IPQ5010.
Where Are the Application Scenarios?
Industrial WiFi demands reliability, long-range coverage, and high bandwidth. The Wallys DR5018S series is designed for applications such as:
  • Smart factories
  • Security surveillance
  • Industrial automation
  • Outdoor deployments
  • IoT & edge computing networks
These environments require low latency, enhanced throughput, and better multi-device connectivity, making WiFi 6 a necessity.
The Former Advantages of DR4019
The DR4019, based on IPQ4019, has long been a go-to solution for many industrial applications due to its stability, affordability, and performance in WiFi 5 networks. It has served well in demanding environments, offering a balance between cost and capability. However, as connectivity demands grow, an upgrade is essential.
Why Upgrade to WiFi 6?
WiFi 6 offers significant improvements over WiFi 5, such as:
  • Higher speeds – Increased data rates for better efficiency.
  • Lower latency – Ideal for real-time applications.
  • Improved device handling – Supports a higher number of connected devices efficiently.
  • Better power efficiency – Crucial for IoT applications.
  • OFDMA & MU-MIMO – Ensures smooth data transmission in congested environments.
These advantages make WiFi 6 an obvious choice for next-gen industrial applications.
Is Industrial WiFi 6 Much More Expensive Than WiFi 5?
One common concern is pricing. While WiFi 6 solutions may have a slightly higher upfront cost, they offer long-term benefits such as improved performance, extended lifespan, and reduced operational costs. With Wallys, you get cost-effective WiFi 6 solutions tailored for industrial use.
When Should I Choose WiFi 6 and When Should I Opt for WiFi 7?
  • Choose WiFi 6 (IPQ5018/IPQ5010) if you need a reliable, cost-effective, and high-performance upgrade from WiFi 5.
  • Consider WiFi 7 when you require multi-link operation (MLO), extremely high throughput, and lower interference in advanced applications.
For most industrial needs today, WiFi 6 remains the best balance of performance and cost.
Why Choose Wallys?
Wallys provides end-to-end industrial wireless solutions, combining hardware and software expertise:
  • Custom Hardware & Firmware Development – Tailored solutions for specific applications.
  • Advanced WiFi Protocol Optimization – Specialized features for industrial use.
  • OEM/ODM Services – Fully customized manufacturing options.
  • Expert Software Support – In-house development for specialized industrial protocols.
  • Strong After-Sales & Technical Support – Ensuring smooth deployments and long-term reliability.
Wallys DR5018S Series – Tailored Industrial Solutions
Wallys has launched three models of the DR5018S router board to meet diverse industrial requirements:
https://www.wallystech.com/Routerboard/DR5018S-wifi6-IPQ5018-2.4G-5G-6G-triband-11ax-MU-MIMO-OFDMA-QCN6122-QCN6102.html
Get in Touch
Ready to upgrade? Contact our sales engineers for more details: 📩 sales1@wallystech.com
GMT+8, 2026-11-3 02:53 , Processed in 0.019696 second(s), 8 queries , Gzip On, Redis On.
