查看: 820|回复: 0
[供应] QCN6274: A Smart, Scalable Wi-Fi 7 Radio for Next-Gen Wireless
发表于 2025-7-1 14:32:42 | 显示全部楼层 |阅读模式
As Wi-Fi 7 (802.11be) begins to reshape the wireless landscape, many developers and system integrators are searching for a solution that balances performance, efficiency, and design flexibility.
That’s where QCN6274 steps in.
At Wallys, we’re integrating QCN6274 into our modular router board platforms — offering OEMs and industrial clients a triple-band Wi-Fi 7 solution that works in real-world deployments, not just whitepapers.
📡 What Is QCN6274?
QCN6274 is a Qualcomm tri-band Wi-Fi 7 radio module supporting:
  • 2.4GHz + 5GHz + 6GHz
  • Up to 4x4 MIMO per band
  • 320 MHz ultra-wide channels (in 6GHz)
  • Multi-Link Operation (MLO) for seamless multi-band communication
  • Support for 4096-QAM, OFDMA, and other Wi-Fi 7 PHY/MAC features
This module is ideal for building:
  • 🔧 High-performance industrial routers
  • 🏙️ Smart city APs and mesh nodes
  • 🚚 Embedded wireless gateways for logistics and energy
  • 🏢 Enterprise-class APs and fixed wireless access (FWA)
🔄 Modular Hardware, Maximum Flexibility
We’ve successfully integrated QCN6274 into several Wallys platforms, including:
🔷 DR5332 (IPQ5332)
  • Qualcomm’s entry Wi-Fi 7 SoC
  • Perfect match for mid-range Wi-Fi 7 applications
  • Up to 2.5G Ethernet, OpenWrt/QSDK support
🔷 Upcoming IPQ5424 Board
  • Quad-core ARM Cortex-A55 @ 1.8GHz
  • PCIe 3.0 for QCN6274, M.2/USB/PoE ready
  • Designed for smart city and industrial-grade Wi-Fi 7 rollouts
The result?
A production-ready Wi-Fi 7 platform that is both modular and scalable, capable of serving entry, mid, and high-end market needs.
🧠 QCN6274 vs QCN9274: Know the DifferenceFeatureQCN6274QCN9274
Bands2.4G + 5G + 6G2.4G + 5G + 6G (Tri-Band)
Typical PairingIPQ5332 / IPQ5424IPQ9574 / IPQ5424
MIMO4x4 per band4x4 per band
Max Bandwidth320 MHz (6GHz)320 MHz (6GHz)
Use CaseSmart city, embedded meshCarrier-grade CPE, AP backbone
Price/Performance⭐⭐⭐⭐⭐⭐⭐⭐⭐
QCN6274 gives you Wi-Fi 7 capability without overbuilding — ideal for cost-sensitive, power-conscious deployments that still demand top-tier throughput and modern features.
🛠️ Wallys Adds More Than Just Hardware
With our full-stack integration services, we provide:
  • 🔄 Pre-integrated OpenWrt/QSDK support
  • 🛠️ Firmware tuning and MLO optimization
  • 📐 RF calibration and antenna matching
  • 🔩 Enclosure + accessory kits for turnkey deployment
  • 🧪 Lab-tested performance reports for volume clients
📩 Want to test QCN6274 in your next product?
Email our team at sales1@wallystech.com for datasheets, test logs, and sample availability.
🔗 Explore more of our Wi-Fi 7 portfolio: www.wallystech.com
#QCN6274 #WiFi7 #80211be #RouterBoard #WallysTech #OpenWrt #IndustrialWiFi #SmartCity #QSDK #IPQ5332 #IPQ5424 #EmbeddedWireless #WirelessSolutions #ODM #OEM
GMT+8, 2026-10-23 22:32 , Processed in 0.092236 second(s), 7 queries , Gzip On, Redis On.
