查看: 2450|回复: 0
[供应] Low cost wifi6 solution|IPQ5018 with QCN6122/QCN9074 realize 2x2 2.4G Wifi 6E
发表于 2023-6-14 16:20:14 | 显示全部楼层 |阅读模式
IPQ5018 supports a wide range of Wi-Fi standards, including 802.11ac and 802.11ax, enabling you to benefit from the latest advancements in wireless technology. Additionally, it is fully compatible with 802.11a/b/g/n, ensuring seamless integration with existing network infrastructures.
With its versatile design, IPQ5018 offers support for various peripheral interfaces such as USB and PCIe. This allows for easy connectivity and seamless communication with other devices, enabling you to expand your network and connect with a diverse range of equipment effortlessly.
Whether you're seeking faster speeds, improved coverage, or enhanced network efficiency, IPQ5018 provides the performance and flexibility you need for your Wi-Fi network applications.
In this blog post, we will take a closer look at the DR5018 routerboard developed by Wallystech. Powered by the IPQ5018 chip, this routerboard offers impressive features and performance while maintaining an attractive price point. Let's delve into its specifications and wireless capabilities.
Specifications:
The DR5018 (IPQ5018) routerboard is equipped with four 1G Ethernet ports and one 1G POE Ethernet port, making it a highly cost-effective choice. It utilizes the IPQ5018 chip, which operates at a frequency of 1GHz, slightly lower than the DR6018's 1.8GHz. This frequency reduction helps optimize costs and is powered by a dual-core processor.
Wireless Capabilities:
The DR5018(IPQ5018) routerboard supports 2x2 MIMO on the 2.4GHz band, offering a maximum speed of 573Mbps.
To expand into the 6E frequency band, it can be paired with the DR6122-6E (QCN6122) or DR9074-6E (QCN9074) modules. The DR9074-6E supports 4x4 MIMO with a maximum speed of 4949Mbps, while the DR6122-6E supports 2x2 MIMO with a maximum speed of 2.4Gbps.
For expanding into the 5GHz frequency band, it can be paired with the DR9074-5G (QCN9074) module. The DR9074-5G supports 4x4 MIMO with a maximum speed of 4949Mbps, specifically designed to support 4x4 MIMO in 160MHz channels.
Modulation:
The DR5018 (IPQ5018) routerboard supports various modulation schemes such as 64-QAM, 256-QAM, 1024-QAM, and 4096-QAM. Each modulation level provides a 20% increase in speed, ensuring efficient data transmission.
Wireless Speed Comparison:
Here are some speed comparisons for the 2.4GHz and 5GHz bands in 802.11ax mode (40MHz, 80MHz, and 160MHz):
2.4GHz Speed Rates (802.11ax, 40MHz): Due to heavy interference in the 2.4GHz band, achieving high speeds in real-world usage scenarios can be challenging.
5GHz Speed Rates (802.11ax, 80MHz):
5GHz Speed Rates (802.11ax, 160MHz):
A combination of 4x4 MIMO, 160MHz channel width, and 4096-QAM modulation can deliver an impressive speed of 5764.7Mbps.
Product Enclosure:
Wallystech offers a range of enclosures for the DR5018(IPQ5018) routerboard. They have options available for both indoor and outdoor installations, with the ability to customize designs based on specific customer requirements.
Conclusion:
The DR5018 routerboard, powered by the IPQ5018 chip, provides a cost-effective WiFi 6E solution. With its dual-core processor, extensive wireless capabilities, and support for the latest WiFi technologies, it offers an excellent balance of performance, coverage, and affordability. To unlock the true potential of wireless connectivity, consider upgrading to Wallystech's DR5018 routerboard and embracing their cost-effective WiFi 6 solution.
. For any inquiries or further information, you can reach out to their sales team at sales1@wallystech.com.
Embrace the power of Wallystech's WiFi 6 Solution today and enjoy reliable, high-speed wireless connectivity that keeps you connected, fast, and ahead of the curve.
GMT+8, 2026-11-19 17:19 , Processed in 0.061491 second(s), 10 queries , Gzip On, Redis On.
