查看: 1520|回复: 0
[供应] Wallys|DR4019S|IPQ4019|Support 11ABGN/802.11AC
签到总天数:8天
签到总奖励:36金币
发表于 2023-3-8 13:56:54 | 显示全部楼层 |阅读模式
If you're in the market for a high-performance Wi-Fi solution for your business or home, look no further than the Qualcomm IPQ4019. This cutting-edge system-on-a-chip (SoC) packs a powerful punch, offering exceptional speed, range, and reliability for even the most demanding networking applications.
At the heart of the IPQ4019 lies a quad-core processor running at up to 717MHz, providing lightning-fast performance that can handle even the heaviest network traffic. The SoC also includes advanced 2.4GHz and 5GHz radios with support for 802.11ac wave 2, MU-MIMO, and beamforming technologies, delivering fast and reliable Wi-Fi connectivity to all your devices.
But that's not all. The IPQ4019 also includes a range of advanced features designed to optimize your network performance, including:
Multi-gigabit Ethernet: With support for Gigabit Ethernet and advanced switch capabilities, the IPQ4019 delivers lightning-fast wired connectivity for all your devices.
USB 3.0: Connect your favorite peripherals and storage devices for even more functionality and convenience.
PCIe: Enjoy even more connectivity options, including support for high-speed PCIe devices.
Robust security: With advanced encryption and authentication technologies, the IPQ4019 helps keep your network safe from threats and intruders.
Whether you're setting up a new business network, upgrading your home Wi-Fi, or simply looking for the ultimate in performance and reliability, the Qualcomm IPQ4019 is the ideal solution for your needs.
At the heart of the DR4019S lies an industrial-grade IPQ4019 chipset, which provides the power and performance needed to handle even the most demanding networking applications. With two high-power 5G radio modules and two high-power 2.4G radio modules, the DR4019S delivers exceptional coverage and signal strength, ensuring that your devices can stay connected no matter where you are in your facility.
The DR4019S supports a wide frequency range, including 5.180GHz to 5.825GHz and 2.412GHz to 2.482GHz, and provides support for both 802.11abgn and 802.11ac wireless networking standards. It also includes MMCX connectors for both 5G and 2.4G radios and supports a range of bandwidth options, including 20MHz, 40MHz, and 80MHz.
One of the standout features of the DR4019S is its rugged and reliable design. With an industrial-grade housing and RoHS compliance, the DR4019S is built to withstand harsh environments and ensure a high level of protection for human health and the environment.
Whether you're running a factory, warehouse, or other industrial facility, the DR4019S is the ideal choice for your wireless networking needs. With its powerful performance, wide frequency range, and rugged design, the DR4019S is sure to meet and exceed your expectations.
Featuring withindustrial-grade IPQ4019  chipset
Integrated with 2x 2 5G high power
Radio module and 2x2 2.4G high power  Radio module
Support 5.180GHz to5.825GHz Frequency Range;
Support 2.412GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
20MHz/40MHz/80MHz Bandwidth
RoHS compliance ensure a high level
protection of human health and the environment from risks that can be posed by
Symbol
Parameter
CPU
IPQ4019Quad core ARM Cortex A7 at 716.8 MHz
Antenna Connector
2 x 5G MMCX connectors;2x2.4G MMCX
10/100/1000Mbps
     Gigabit Ethernet
2xRJ45
DC Jack
12 power supply
ROHS Compliance
YES
Dimension
65mmx35mm x 16mm
Max Power
12V x 0.8A= 9.6W
Nor Flash
32MB
DDR
256MB
Are you looking for a reliable and experienced partner to help you develop and produce wireless communication products? Look no further than Wallys Communications.
At Wallys, we specialize in the research and development, production, and OEM/ODM/JDM services of wireless communication products. Our team of skilled engineers has a proven track record in areas such as RF and embedded communications, network protocol, firmware, PCB design, and more. We use advanced equipment to ensure that our products are not only of the highest quality, but also meet the specific needs of our customers.
Whether you're in need of custom-designed wireless communication products, or looking to optimize existing ones, Wallys Communications has the expertise to help. Contact us today to learn more about our services and how we can help you achieve your wireless communication goals.
MAIL:sales3@wallystech.com
GMT+8, 2026-3-28 17:12 , Processed in 0.073550 second(s), 13 queries , Gzip On, MemCached On.
