查看: 1584|回复: 0
[供应] Wallys||adapter card Linux,WiFi-modules,4-miniPCIE-slot QCA9882/QCA9880/MT791...
签到总奖励:18金币
发表于 2022-10-26 17:24:56 | 显示全部楼层 |阅读模式
Wallys||adapter card Linux,WiFi-modules,4-miniPCIE-slot QCA9882/QCA9880/MT7915/AX200NGW
Today I would like to introduce a wallys board: DR2G41
Adapter Card 4 x Mini PCIe Card 4 x M.2 Card
DR2G41 is an adapter card with four MiniPCIe and four M.2 slots. It can be used in a PC with a PCIe slot. Use this new  adapter to expand your connectivity and upgrade your device to use the latest miniPCIe and m.2 interface cards. Each  comes with both low and regular profile brackets.
Brackets include holes for mounting SMA connectors, or for using as cable exit holes.
    Specifications
    Parameter
    Rating
    Unit
    Input voltage
    12
    V
    Output Voltage
    3.3
    V
    Operating Temperature
    -40 to +70
    ?C
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    ROHS Compliance
    YES
    Switch control instruction
    Switch
    up/down
    Operation
    Switch 1
    up
    M.2-1
    down
    MiniPCIE-1
    Switch 2
    up
    M.2-2
    down
    MiniPCIE-2
    Switch 3
    up
    M.2-3
    down
    MiniPCIE-3
    Switch 4
    N/A
    M.2-4 and MiniPCIE-4 can work simultaneously,not controlled by the switch 4
Let's look at each moudle it can support.
AX200 NGW is a network adapter released by Intel in 2019 that supports wireless communication protocol 802.11ax (WiFi6), communication bandwidth 160MHz, MU-MIMO technology, OFDMA orthogonal frequency division multiple access (OFDMA).
DR600vx(Quaclomm qca9880/qca9882 chipset)
The difference between DR600vx and DR900vx is that DR600VX is 2x2 2.4G/5G, the chip can be QCA9880/QCA9882,DR900vx is 3x3 2.4G/5G, the chip can only be QCA9880.
QCA9880 802.11ac Dual band
QCA9880 2x2 2.4G/5G FCC/CE
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 24dBm & 5GHz max 23dBm output power
IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n
2x2 MIMO Technology, up to 867Mbps
Mini PCI Express edge connector
Support the Frequency 4920MHz~4980MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check
(LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Qualcomm QCA9880 is a highly integrated WLAN SoC that can be used in 5GHz 802.11ac or 2.4/5GHz 802.11n WLAN products. QCA9880 supports 3x3 MIMO and can be used for high-speed wireless data transfer applications. QCA9880 integrates a MAC, PHY, ADC, DAC, 3x3 MIMO wireless transceiver that supports multiple protocols. QCA9880 uses PCI-e interface to communicate with the outside world.
Qualcomm Atheros QCA9882 is a highly integrated wireless LAN (WLAN) system-on-chip (SoC) for 5GHz 802.11ac or 2.4/5GHz 802.11n WLAN applications. The QCA 9882 integrates an on-board cpu for the wireless LAN physical layer (Phy) and lower level Settings of the rf to offload the host processor to other tasks
DR7915
WiFi6 MiniPCIe Module 2T2R
2×2.4GHz 2x5GHz MT7915 MT7975
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
The MT7915DAN is a highly integrated Wi-Fi A/D chip which supports 573+1201 Mbps PHY rate and Bluetooth combo. It fully complies with IEEE 802.11ax and backward compatible with IEEE 802.11 a/b/g/n/ac standards, offering feature-rich wireless connectivity at high standards, and delivering reliable, cost-effective throughput from an extended distance. Optimized RF architecture and baseband algorithms provide superb performance and low power consumption. Intelligent MAC design deploys a high efficient offload engine and hardware data processing accelerators which fully offloads WiFi task of the host processor. The MT7915DAN is designed to support standard based features in the areas of security, quality of service and international regulations, giving end users the greatest performance any time and in any circumstance.
Wallys has a history of 10 years, so it can be said that its hardware and software development design is very mature. It independently designs and develops software to support the current trend of wifi, including openwrt, MT and QSDK, which has been recognized and trusted by more customers.
There are many companies in the market that develop and design wireless motherboards (moudle, antenna), but for some reasons, the design and development is complicated and the cost is high, so more companies are not willing to take on such customers, and wallys can help you complete the project, which is also an advantage.
For example, if you buy a board from another company and you need wallys' moudle, but the board may not be compatible with moudle, this problem is troublesome, and wallys can help the customer solve the problem to some extent.
More customers can get technical support, so as to obtain more customer sources. This is not only for helping customers, but also for wallys' strong hardware and software development ability to gain customers' trust and support.
wallys also supports custom development if the client has a custom product project.
More questions can be contacted by email, at any time for you to answer questions
Skype/EMAIL:sales@wallystech.com
GMT+8, 2026-11-3 00:59 , Processed in 0.023667 second(s), 10 queries , Gzip On, Redis On.
