查看: 1907|回复: 0
[Qualcomm(CSR)] Wallys//IPQ6000 IPQ6010 802.11ax 2x2 2.4G 2x2 5G 1.7Gbps/2 on board radios (D...
签到总天数:8天
签到总奖励:36金币
发表于 2022-10-28 15:36:14 | 显示全部楼层 |阅读模式
IPQ6000 IPQ6010 802.11ax 2x2 2.4G 2x2 5G 1.7Gbps/2 on board radios (Dual Band Concurrent Radio)
1. DR6000
https://www.wallystech.com/Routerboard/DR6000-wifi6-Qualcomm-IPQ6000-2T2R-2-GE-port-MU-MIMO-OFDMA-802.11AX-support-OpenWRT.html
Qualcomm-Atheros IPQ6000
Quad-core ARM 64 bit A53s 1.2GHz processor
2.4GHz, 2x2 MU-MIMO OFDMA Technology, up to 573Mbps
5GHz, 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
12
V
Operating Temperature Range
-20 to +70
ºC
Storage Temperature Range
-45 to +90
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.2GHz processor
System Memory
DDR3L 512MB 16-bit interface
Nand Flash
128MB
NOR Flash
16MB
Ethernet Port
2x 1Gbps Ethernet Ports
DC Jack Input
1x DC Jack Connector: 12V
Power Consumption(Board Only)
1TD
On Board Radio
2 radios (Dual band concurrent radio)
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 20dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 2x U.FL Connectors, diplexer allows dual band concurrent operation
Frequency Range
2.412~2.472GHz, 5.150~5.825GHz
2.4GHz Data Rate
5GHz Data Rate
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM,1024QAM
LED
4x LED Indicators
USB /Header
1x MicroUSB 2.0 Port
Serial Port
1x Serial Interface 12 Pin Connectors
Certification
TBD
Humidity
Operating: 5% to 95% (non-condensing) Storage: Max. 90% (non-condensing)
Temperature Range
Operating: TBD Storage: -40ºC to 90ºC
Dimension (Diameter x Height)
100mm x 23.5mm (Without Heatsink)
Wallys could help clients build Prototype. We have a professional technical team supporting. Helping you realize your idea is our aspiration. Everything on RF is our enthusiasm. Different chipsets, different materials, different features, different designs...we could realize all you want. Making your idea visible and alive is what we persuit
We work exclusively with certified labs and also perform testing in-house, covering a wide range of certifications and standard, including FCC,CE and etc. Our lab testing solution provides exhaustive due diligence to limit your company’s risk for liability and ensure that product meet all legal and safety requirement
● OEM Since its inception in 2010, Wallys has had a strong team, including dozens of research and development personnel, a complete set of assembly lines, they play an irreplaceable role.Under the premise of ensuring the product quality, we will deliver the goods at the fastest speed and maximize the product benefit. ● ODM China has a complete wireless communication industry group, which enables ODM manufacturers to obtain the supply of low-cost components. Years of reform and opening-up have made China an ideal low-cost manufacturing base. Compared with the rapid development of the market, ODM services which focus more on design capability and production experience become more competitive
BY:Wallys Communications (Suzhou ) Co., LTD
GMT+8, 2025-9-15 03:57 , Processed in 0.130491 second(s), 15 queries , Gzip On, MemCached On.
