查看: 14311|回复: 0
[供应] Wallys|industrial wifi5 router/IPQ5018 compatible QCN9074/QCN9024 M.2 moudle ...
签到总奖励:18金币
发表于 2022-11-4 11:30:19 | 显示全部楼层 |阅读模式
Today I will introduce the industrial wifi6 router/moudle.
DR5018 is a router based on Qualcomm IPQ5018 chip.
It has two M.2 card slots
A wifi 6e card
One supports M.2card slot for 5G, quectel.
Support BT5.1
It has four 1g Ethernet ports
2x2 2.4 wifi antenna interface.
If you need to customize related hardware parts, wallys can also help you realize your customized functions, such as gps, lte and so on.
Let's take a look at the M.2 card that it supports.
Wallys currently offers three M.2 cards, all of which are based on Qualcomm QCN9074/QCN9024 chips.
These three cards, and all are 4x4, but respectively have three frequency bands of 2.4G/5G/6G, the difference between this card.
Let's just look at one of them in detail.
DR9074-6e, 4x46 g M.2 industrial moudle.
PCI Express 3.0 Interface
Antenna Cable/Port: 4 x MMCX Connectors,4T4R. Antenna Cable/Port: 4 x MMCX Connectors,4T4R.
Frequency Range: 5.925 GHz to 7.125 GHz
To learn more, you can click on the product URL below:
https://www.wallystech.com/Network_Card/DR9074-6E-Wifi6E-Qualcomm-QCN9074-Single-Band-6GHz-4T4R-M-2-E-Key-Interface-802- 11ax.html
Another card supported by DR5018 is the M.2 card, which is the QUECTEL MODULES.
5G RM500Q-GL
5G, LTE cat 16, USB 3.1
GNSS (optional) VoLTE(optional)
5G sub-6GHz module
52.0mm x 30.0mm x 2.3mm
8.4 g
M.2 form factor
Max. downlink 2.5Gbps / 900Mbps uplink
Extended temperature range of -40°C to +85°C
Of course, whether these cards are needed depends on the customer's own project requirements and parameter requirements
If customers need antenna, shell and other requirements, wallys can provide them.
wallys, a technology company that develops, designs and manufactures wireless communications products, has 90% of the world's customers and is a supplier to facebook. From 802.11n to 802.11ax, it has been moving forward, and has been trusted and supported by more and more customers. wallys also supports custom development of software and hardware, including customized products.
Skype/EMAIL/Teams:sales@wallystech.com
WEB:[url=]https://www.wallystech.com/[/url]
GMT+8, 2026-11-3 08:24 , Processed in 0.024903 second(s), 10 queries , Gzip On, Redis On.
