查看: 9967|回复: 8
[QCC5系列] QCC5171 Headset开启不了ANC Tuning
签到总奖励:16金币
发表于 2023-3-16 04:28:27 | 显示全部楼层 |阅读模式
如题,手机跟板子连上可以正常播音乐了,但是不知道ANC Tuning Mode怎么打开,ANC designer提示Error Connecting via USB to device 101
QACT也连不上,Cannot connect to a device. No phones were found. Check connectionand try again.Please check logs for more detials
log如下
  1. <blockquote>Logging started at 03/16/2023 04:27:29by QACTLauncher Version = 7.2.37.0 in QACT_v7.2.37.0_03_16_2023042729.log
复制代码
签到总奖励:16金币
 楼主| 发表于 2023-3-16 04:28:52 | 显示全部楼层
  1. Logging started at 03/16/2023 04:27:29by QACTLauncher Version = 7.2.37.0 in QACT_v7.2.37.0_03_16_2023042729.log
  2. [04:27:31]        [MSMConnectionPlugin]        Critical: Please check if QPST is installed on your PC. If already installed, please restart QPST
  3. [04:27:31]        [ThesyconUSBTransporter]        Information: No connected device is detected.
  4. [04:27:31]        [KymeraTransporter]        Information: Setting kalAccess DLL path failed System.DllNotFoundException: Unable to load DLL 'KymeraWrapper.dll': 动态链接库(DLL)初始化例程失败。 (Exception from HRESULT: 0x8007045A)
  5.    at qcom.mm.avt.QACT.ConnectionPlugins.Kymera_ConnectionPlugin.KymeraTransporter.SetKalAcceessDLLPath(String kalaccessDLLpath)
  6.    at qcom.mm.avt.QACT.ConnectionPlugins.Kymera_ConnectionPlugin.KymeraTransporter.SetKalAccessPath()
  7. [04:27:31]        [KymeraTransporter]        Information: Getting GetConnectedDeviceList in Kymera transport
  8. [04:27:31]        [KymeraTransporter]        Information: Kymera Transport GetConDeviceList
  9. [04:27:31]        [KymeraTransporter]        Error: GetConnectedDeviceListSystem.DllNotFoundException: Unable to load DLL 'KymeraWrapper.dll': 动态链接库(DLL)初始化例程失败。 (Exception from HRESULT: 0x8007045A)
  10.    at qcom.mm.avt.QACT.ConnectionPlugins.Kymera_ConnectionPlugin.KymeraTransporter.GetDeviceListCount(Int32& count, StringBuilder strError)
  11.    at qcom.mm.avt.QACT.ConnectionPlugins.Kymera_ConnectionPlugin.KymeraTransporter.GetConnectedDeviceList(Dictionary`2& devIndex_NameMap)
  12. [04:27:31]        [KymeraTransporter]        Information: End Kymera Transport GetConDeviceList
  13. [04:27:31]        [KymeraTransporter]        Information: Read KalAccess DLL version
  14. [04:27:31]        [KymeraTransporter]        Warning: Exception in reading KalAccess DLL File version
  15. [04:27:31]        [ConnectionManager]        Error: Failed to get Connected Device list. Error:CM_NO_CONNECTION
复制代码
签到总奖励:16金币
 楼主| 发表于 2023-3-16 04:29:03 | 显示全部楼层
签到总天数:22天
签到总奖励:163金币
发表于 2023-3-20 14:10:56 | 显示全部楼层
帮顶
签到总天数:44天
签到总奖励:322金币
发表于 2023-3-21 10:33:24 | 显示全部楼层
同样问题,求助
签到总天数:433天
签到总奖励:6601金币
发表于 2023-4-6 18:58:59 | 显示全部楼层
是不是QACT软件没装好啊?重装或者换个版本试试?驱动有没有装好啊
签到总奖励:16金币
 楼主| 发表于 2023-4-7 13:09:03 | 显示全部楼层
蛮奇怪的,改用ANC Filter Designer就可以了,不过要在pydbg模式下先用指令打开
发表于 2023-7-26 17:10:20 | 显示全部楼层
你好,请问指令调用 HeadsetTest_StartAncTuning() 就死机是怎么回事?
签到总天数:45天
签到总奖励:802金币
发表于 2023-8-2 16:40:24 | 显示全部楼层
学习
GMT+8, 2026-4-10 16:27 , Processed in 0.097588 second(s), 18 queries , Gzip On, MemCached On.
