查看: 1926|回复: 0
[供应] QCN9074/QCN9024/QCN6024 and QCA9880 wireless communication chips Differences ...
签到总奖励:18金币
发表于 2023-3-28 13:44:54 | 显示全部楼层 |阅读模式
There are industrial network cards on the market at present, mainly 2.4G/5G/6G/6E, we look at the difference:
2.4G, 5G, and 6G nics are all wireless network interface cards. They differ mainly in the supported wireless protocols and working bands.
The 2.4G network card supports the IEEE 802.11b/g/n protocol and works at 2.4GHz, which can achieve a maximum transmission rate of 300Mbps. 5G network cards support the IEEE 802.11a/n/ac protocol, working band of 5GHz, can achieve a maximum transmission rate of 866Mbps. The 6G network card supports the IEEE 802.11ax protocol and works in 2.4GHz and 5GHz bands, which can achieve higher transmission rates and lower delays, up to 10Gbps.
Compared with 2.4G network adapters, 5G network adapters have faster transmission rates and better signal stability, but may not have the same signal penetration and coverage as 2.4G network adapters. Compared with 5G network cards, 6G network cards further improve the transmission rate and stability, and have better signal penetration and coverage, but it is still in a relatively preliminary stage and is not popular in the market at present.
Therefore, select a network adapter based on the specific application scenario and requirements. If you need a faster transmission rate, you can choose 5G or 6G network card; If you need better signal penetration and coverage, you can choose a 2.4G network card.
Wallys has produced and developed moudle in the above frequency bands, including two types of M.2 and MINI PCIE.
Specific need to use a lot of chips, but the current market used more chips mainly have the following kinds:
QCN9074, QCN9024, QCN6024 and QCA9880 are all Qualcomm wireless network chips. The differences between them are as follows:
The QCN9074 is Qualcomm's latest generation Wi-Fi 6E wireless network chip that supports the latest Wi-Fi 6E technology and 160 MHz band width with higher speeds and lower latency. It also supports 2.4 GHz, 5 GHz and 6 GHz bands, as well as MU-MIMO and OFDMA technologies.
The QCN9024 is a Wi-Fi 6 wireless networking chip that supports the 160 MHz band width, as well as the 2.4 GHz and 5 GHz bands. It also supports MU-MIMO and OFDMA technologies.
The QCN6024 is a dual-band Wi-Fi 6 wireless networking chip that supports 160 MHz band width, as well as 2.4 GHz and 5 GHz bands. It also supports MU-MIMO and OFDMA technologies.
The QCA9880 is a dual-band 802.11ac/a/b/g/n wireless networking chip that supports 3x3 MIMO technology and 80 MHz band width, as well as 2.4 GHz and 5 GHz bands.
Overall, QCN9074 is the latest generation of Qualcomm wireless network chip, the best performance; QCN9024 and QCN6024 are Wi-Fi 6 wireless network chips. The QCN9024 has higher performance. QCA9880 is a dual-band 802.11ac/a/b/g/n wireless networking chip with slightly lower performance than the first three. Chip selection should be based on specific application scenarios and requirements to make decisions.
Yes, the choice depends on the client's specific project requirements and applications.
编辑
If you are interested or have any questions, please contact: sales@wallystech.com
or web:https://www.wallystech.com/
Wallys is the most worth working with, as Wallys has over 10 years of experience with quaclomm WiFi chips, from ar5414 to ar7161, with full access to the chip's code.
As a result, Wallys can help customers solve many of the problems that customers encounter on WiFi.
Wallys has also developed special protocols such as time division multiple access over WiFi and fast roaming. You can run WiFi within 20km and even disable ack to extend WiFi range.
Wallys can also develop a 4.9Ghz narrow band such as 5/10Mhz.
Wallys is a professional WiFi company that can solve any technical problem you encounter, so we can help customers make many innovative products.
Wallys has a strong software team and hardware team to meet customers' various customized needs for wifi products.
GMT+8, 2026-3-23 07:20 , Processed in 0.071799 second(s), 13 queries , Gzip On, MemCached On.
