查看: 1684|回复: 0
[供应] IPQ8072 or IPQ8072A and QCN9074, suitable for high-end router/enterprise Wi-F...
签到总奖励:18金币
发表于 2023-3-29 13:16:10 | 显示全部楼层 |阅读模式
Wireless communication is becoming more and more popular. In many cases, normal performance and network coverage can meet project requirements.
But at present, more and more customers want more powerful network performance and functions, so let's take a look at the performance and functions that the combination of the following two routers and network cards can produce.
Qualcomm IPQ8072 and IPQ8072A are two network processor chips launched by Qualcomm, which are used in high-end routers and enterprise-class network equipment. They are part of the IPQ807x series of Qualcomm network processor chips, which are widely used in network equipment such as wireless routers, switches, enterprise-level Wi-Fi access points, and network storage devices.
Both chips use Qualcomm's self-developed Krait CPU architecture, which has four 64-bit processor cores with a main frequency of up to 2.2GHz, which can provide powerful performance and processing capabilities. In addition, they are equipped with Qualcomm Adreno 680 GPU and Hexagon 680 DSP to support efficient data processing and calculation.
The biggest difference between IPQ8072 and IPQ8072A is the network interface. IPQ8072 supports 2.5Gbps Ethernet interface, while IPQ8072A supports 10Gbps Ethernet interface, so it is more suitable for enterprise-class network equipment for high-speed data transmission. In addition, both chips support the 802.11ax Wi-Fi standard (also known as Wi-Fi 6), as well as multiple wireless bands, which can provide faster wireless speeds and greater network coverage.
In short, both IPQ8072 and IPQ8072A are Qualcomm's high-end network processor chips with powerful performance and processing capabilities, and are widely used in network devices such as wireless routers, switches, enterprise-level Wi-Fi access points, and network storage devices. Which chip to choose depends on the specific application scenarios and needs.
What kind of performance and functions does the above two chips match with QCN9074?
Pairing Qualcomm IPQ8072 or IPQ8072A with QCN9074 can provide powerful network performance and features, especially in high-end network equipment such as enterprise-level Wi-Fi access points. QCN9074 is a wireless network chip that supports 802.11ax Wi-Fi standard. It can provide higher wireless speed and larger network coverage when used in combination with IPQ8072 or IPQ8072A.
As a network processor, IPQ8072 or IPQ8072A chip can provide powerful processing capability and performance. As a wireless network chip, QCN9074 supports technologies such as MU-MIMO, OFDMA and TWT, which can achieve higher data transmission speed and lower network delay.
Specifically, pairing IPQ8072 or IPQ8072A with QCN9074 provides the following features and functions:
High-speed wireless transmission: QCN9074 supports 802.11ax Wi-Fi standard, which can provide higher wireless speed and larger network coverage, and is suitable for high-density data transmission scenarios.
Multi-user transmission: MU-MIMO technology can enable multiple users to transmit data at the same time, improving network efficiency.
Multi-user access: OFDMA technology allows multiple users to access the network at the same time to achieve higher network capacity.
Low-latency transmission: TWT technology can realize low-power standby of devices, thereby reducing network delay.
Powerful processing capability: IPQ8072 or IPQ8072A chip can provide powerful processing capability and can support high-speed data transmission and various network protocols.
In short, combining IPQ8072 or IPQ8072A chip with QCN9074 can provide powerful network performance and functions, which are suitable for high-end routers, switches, enterprise-level Wi-Fi access points and other network equipment.
GMT+8, 2026-10-23 23:24 , Processed in 0.022591 second(s), 9 queries , Gzip On, Redis On.
