查看: 1835|回复: 0
[供应] MINI PCIE cards MT7915 QCA9882 QCA9880 QCN9074 QCN9024 Chipset|Wallys
发表于 2023-4-17 17:39:31 | 显示全部楼层 |阅读模式
Mini PCIe, or Mini Peripheral Component Interconnect Express, is a miniature version of the PCIe interface used to connect peripheral devices like network adapters, graphics cards, and storage devices to a computer's motherboard. The Mini PCIe standard was designed specifically for smaller form factors like embedded systems and laptops where space is at a premium. It has a smaller physical footprint and lower power consumption than the standard PCIe, and supports multiple communication protocols, including USB, SATA, and PCI, making it versatile for a wide range of devices.
Wallys has developed mini PCIe cards using the MT7915, QCA9882, QCA9880, QCN9074, and QCN9024 chipsets.
This article will highlight the benefits of Wally's Mini PCIe cards and how they can enhance network connectivity.
Below is an overview of the Minipcie cards from wallys.
DR7915:Cost-effective MTK MT7915 DBDC solution
The MT7915+MT7975 chipset provides high-performance wireless networking with a maximum output power of 23dBm on 2.4GHz and 20dBm on 5GHz frequencies. It is compliant with IEEE 802.11ac/ax standards and backward compatible with 802.11ax/ac/a/b/g/n. Featuring 2x2 MIMO technology on both 2.4G and 5G frequencies, it can achieve speeds of up to 1.8Gbps. The chipset is designed with a Mini PCI Express edge connector and supports frequencies ranging from 2412MHz to 2482MHz and 5180MHz to 5825MHz.
In addition to complying with RoHS standards for environmental protection, this chipset supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio Combining (MRC), and Space Time Block Code (STBC) technologies. It also supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards, as well as Dynamic Frequency Selection (DFS).
To ensure quality assurance, each card is individually calibrated.
DR882:
The device is equipped with an industrial-grade Atheros QCA9882 chipset and integrated with 2x2 5G high power radio cards. It operates within the 4.940GHz to 5.825GHz frequency range and features 2 x 5G MMCX connectors with bandwidth options of 20MHz, 40MHz, or 80MHz. It supports 802.11ac/an standards and is RoHS compliant, ensuring protection of human health and the environment from risks posed by chemicals.
DR900VX: 3x3 Excellent Performance with QCA9880 CHIPSET,FCC/IC/CE certified
The device features the Qualcomm-Atheros QCA9880 chipset with 2.4GHz output power up to 26dBm and 5GHz output power up to 25dBm. It is IEEE 802.11ac compliant and backward compatible with 802.11a/b/g/n standards. The device utilizes 3x3 MIMO technology, with speeds of up to 1.3Gbps. It also features a mini PCI Express edge connector and is RoHS compliant, ensuring protection of human health and the environment from risks posed by chemicals. The device supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio Combining (MRC), and Space Time Block Code (STBC), as well as IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards. It also supports Dynamic Frequency Selection (DFS) and has FCC, CE, and IC certifications.
DR600VX:2x2 Excellent Performance with QCA9880 CHIPSET,FCC/CE certified
Chipset: Qualcomm-Atheros QCA9880
Output power: 2.4GHz max 24dBm & 5GHz max 23dBm
MIMO Technology: 2x2, with speeds up to 867Mbps
Connector: Mini PCI Express edge connector
Frequency Range: Supports 4920MHz~4980MHz
RoHS compliant for protection of human health and environment from chemical risks
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio Combining (MRC), and Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
DR9074E
Key Features:
Equipped with Qualcomm Atheros QCN9074 QCN9024 chipset
Each chain can reach a maximum transmission power of 20dBm
Supports data rates up to 4949Mbps
Frequency range options: 5.1805.825GHz, 5.9257.125GHz, or 5.180~7.125GHz
Utilizes MiniPCIe connector
Utilizes PCI Express 3.0 Interface
Applications:
Ideal for security surveillance
Suitable for commercial radio coverage
Suitable for hotel wireless applications
Suitable for forest fire protection engineering
Suitable for country coverage
Suitable for some special scene applications
Company Introduction
Wallys Communications has a strong advantage in having a professional R&D team composed of experienced software and hardware engineers. On the software side, we possess a deep understanding of Linux operating systems and chip-level Uboot, particularly with regards to driver and Qualcomm chip development. This expertise allows us to offer customers performance optimization and modifications to WiFi protocols, such as our successful design of fast roaming and TDMA protocols. We have also developed anti-interference measures to enable long-distance data transmission of up to 20km and can assist customers in integrating their functions (e.g. GPS) into their devices. We are confident in our ability to provide high-quality services.
Regarding hardware, we have our own SMT and can collaborate on manufacturing. As RF adjustment and matching are common challenges in hardware production due to manufacturing errors, our experienced RF hardware engineers can guarantee product quality and stability. We have also implemented special features such as frequency conversion from 2.4G to 900M for our clients. We offer one-stop services to customers and are committed to establishing long-term win-win partnerships.
Email:sales1@wallystech.com (Lily)
Website: https://www.wallystech.com/
GMT+8, 2026-5-10 18:46 , Processed in 0.090417 second(s), 11 queries , Gzip On, MemCached On.
