查看: 1067|回复: 1
[供应] QSDK linux/IPQ6010+QCN9074/QCN9024 M.2 2.4G/5G moudle WPA3 Encrypt up to 1201...
签到总奖励:18金币
发表于 2023-4-20 13:57:25 | 显示全部楼层 |阅读模式
QSDK linux/IPQ6010+QCN9074/QCN9024 M.2 2.4G/5G moudle WPA3 Encrypt up to 1201Mbps
IPQ6010 wifi6 wireless solution
High performance: IPQ6010 is equipped with Qualcomm's own Kryo processor, which supports multi-core processing and has a dominant frequency of up to 1.8GHz, providing excellent wireless performance and processing power.
Wi-Fi 6 Standard support: IPQ6010 supports the IEEE 802.11ax standard, also known as Wi-Fi 6, providing higher wireless speeds and lower latency. IPQ6010 is also backward compatible with devices that support the IEEE 802.11a/b/g/n/ac standard.
MU-MIMO technology: The IPQ6010 supports the multi-user multi-input Multi-output (MU-MIMO) technology to communicate with multiple devices at the same time, providing higher network efficiency and performance.
Strong security: IPQ6010 integrates Qualcomm's own security technologies, including WPA3 encryption, 802.11i security protocol and advanced authentication and data protection functions, to ensure the security and privacy protection of network connections.
Comprehensive Network management: IPQ6010 supports Qualcomm's Network Manager software platform and provides advanced network management and optimization features, including intelligent bandwidth management, traffic scheduling, device management, and Quality Service (QoS), providing more control and optimization options for network managers.
Rich hardware interfaces: The IPQ6010 provides rich hardware interfaces, including Ethernet, USB, UART, SDIO, etc., to facilitate the connection and communication with various external devices.
Comprehensive application scenario support: The IPQ6010 is suitable for a variety of application scenarios, including routers, gateways, Repeaters, wireless base stations, industrial controls, and smart homes, providing flexible deployment and integration options.
IPQ6010 supports a variety of frequency bands, including but not limited to the following:
2.4GHz band: IPQ6010 supports IEEE 802.11b/g/n and provides wireless speeds up to 600 Mbps in the 2.4GHz band.
5 GHz band: IPQ6010 supports IEEE 802.11a/n/ac/ax standard, providing higher wireless speed and performance in the 5 GHz band, up to 4.8 Gbps.
6 GHz band: IPQ6010 supports the emerging 6 GHz band in IEEE 802.11ax standard, providing more wireless spectrum resources to support higher wireless speed and capacity. This is advantageous for providing high density wireless network connectivity, such as in public places, enterprises and high density residential areas.
It and QCN9074/QCN9024 M.2 card implementation performance:
QCN9074: QCN9074 is an M.2 format Wi-Fi 6 module for embedded devices and mobile devices such as laptops, tablets, industrial control devices, etc. It uses a PCIe interface to connect hosts and supports high-speed and low-power wireless connection. It is suitable for embedded devices to implement Wi-Fi 6.
QCN9024: QCN9024 is an M.2 format Wi-Fi 6 module designed for use in industrial control, Internet of Things devices and embedded systems. With its small size and low power consumption, it is suitable for wireless connectivity in embedded devices.
The performance of the IPQ6010, QCN9074, and QCN9024 varies according to the application scenario, configuration, and usage conditions. Generally speaking, IPQ6010, as a high-performance Wi-Fi 6 chip, can provide higher transmission rates, lower latency, and better network capacity. It is suitable for network devices requiring high-performance wireless networks. QCN9074 and QCN9024, as embedded modules, may have some choices in size, power consumption and performance, and are suitable for embedded devices and Internet of Things applications.
Email:sales@wallystech.com
WEB:Wallys 802.11ax, wifi 6, IPQ4029,IPQ4019,IPQ6018,IPQ6000.Router board, wireless card.Access Point.
签到总天数:44天
签到总奖励:280金币
发表于 2025-4-28 09:51:06 | 显示全部楼层
THANK YOU
GMT+8, 2025-6-13 08:39 , Processed in 0.154464 second(s), 16 queries , Gzip On, MemCached On.
