查看: 1463|回复: 0
[供应] IPQ9574 support latest WiFi security protocol (WPA3 OWE) larger bandwidth
签到总奖励:18金币
发表于 2023-4-26 09:57:10 | 显示全部楼层 |阅读模式
IPQ9574 support  latest WiFi security protocol (WPA3 OWE) with larger bandwidth 160 MHz
IPQ9574 is a high-performance wireless network chip widely used in routers, wireless access points and other wireless devices. It has the following advantages over Wi-Fi:
High performance: IPQ9574 adopts high-performance ARM Cortex-A53 processor, which has fast running speed and strong processing ability, and can support high-speed wireless data transmission and processing requirements. It is also equipped with high-performance Wi-Fi 6 (802.11ax) and Bluetooth 5.0 technology, which can provide excellent performance and stability in high-density wireless environments.
Large capacity: IPQ9574 supports multi-user multiple-input multiple-output (MU-MIMO) technology, which can handle data transmission requests from multiple devices at the same time, improving the capacity and throughput of the wireless network. This means that when there are many devices connected at the same time, IPQ9574 can better manage and schedule wireless resources to avoid network congestion and performance degradation.
Advanced Wireless Security: The IPQ9574 supports the latest Wi-Fi security protocols, including WPA3 and Enhanced Open (OWE), providing a higher level of wireless network security protection. In addition, it also supports hardware-level security encryption engine, which can protect the privacy and security of user data.
Powerful network management and control functions: IPQ9574 integrates rich network management and control functions, including traffic scheduling, load balancing, intelligent channel selection, dynamic spectrum management, etc., which can help network administrators optimize wireless network performance and provide better user experience. experience.
Compatibility: IPQ9574 supports the Wi-Fi 6 standard and is backward compatible with Wi-Fi 5 (802.11ac) and earlier Wi-Fi standards, so it can be compatible with various versions of Wi-Fi devices and can be used in various Flexible deployment and use in network environment.
The IPQ9574 chip supports multiple wireless frequency bands and bandwidths, depending on product design and configuration. In general, IPQ9574 supports the following frequency bands and bandwidths:
Frequency band support: IPQ9574 supports two main Wi-Fi frequency bands, 2.4 GHz and 5 GHz. The 2.4 GHz band typically has a longer range but a relatively low transmission rate, while the 5 GHz band has a higher transmission rate but a shorter range. IPQ9574 can support these two frequency bands at the same time, providing more flexible wireless network connection options.
2.4 GHz frequency band: This was one of the earliest frequency bands for Wi-Fi and is still one of the most widely used today. The advantage of the 2.4 GHz frequency band is that the signal has a long range of propagation and can penetrate obstacles, which is suitable for wireless networks with a large coverage area. However, since the 2.4 GHz frequency band is used by many other devices (such as Bluetooth, microwave ovens, etc.), there may be high interference, resulting in a relatively low transmission rate. In the 2.4 GHz band, the bandwidth supported by the IPQ9574 is typically 20 MHz and 40 MHz.
5 GHz frequency band: This is a newer Wi-Fi frequency band that provides greater bandwidth and higher transmission rates, and is suitable for applications that require high-speed data transmission. The 5 GHz band has less interference than the 2.4 GHz band and generally provides more stable and efficient wireless network connections. In the 5 GHz frequency band, the bandwidth supported by IPQ9574 is usually 20 MHz, 40 MHz, 80 MHz and 160 MHz, among which the bandwidth of 80 MHz and 160 MHz can provide higher transmission rates, suitable for high-speed data transmission and high-density environments Applications.
Bandwidth Support: The IPQ9574 supports multiple bandwidth configurations including 20 MHz, 40 MHz, 80 MHz and 160 MHz. The wider the bandwidth, the higher the wireless transmission rate can be supported in theory, but at the same time, it may also affect the propagation range and penetration ability of wireless signals. The specific bandwidth configuration can be adjusted and configured according to product design and application requirements.
As a high-performance wireless network chip, the IPQ9574 chip supports a variety of wireless solutions, including:
802.11a/b/g/n: IPQ9574 supports IEEE 802.11a/b/g/n standard, which is one of the common standards of Wi-Fi technology, covering two frequency bands of 2.4 GHz and 5 GHz, and supports multiple bandwidth configurations (including 20 MHz, 40 MHz, 80 MHz, and 160 MHz), offering different transmission rates and coverage options.
802.11ac: IPQ9574 also supports IEEE 802.11ac standard, which is a higher-performance Wi-Fi technology, mainly working in the 5 GHz frequency band, supporting larger bandwidth (including 80 MHz and 160 MHz), providing higher Transmission rate and lower latency, suitable for application scenarios that require high-speed data transmission and low latency.
802.11ax (Wi-Fi 6): IPQ9574 also supports the latest IEEE 802.11ax standard, also known as Wi-Fi 6, which is a more advanced Wi-Fi technology with higher transmission rate and lower Latency and better network efficiency. Wi-Fi 6 supports greater bandwidth (including 80 MHz and 160 MHz), and introduces a series of new technologies such as OFDMA, MU-MIMO, TWT, etc. to provide better performance and user experience.
Other wireless protocols: In addition to Wi-Fi technology, IPQ9574 can also support other wireless protocols, such as Bluetooth (Bluetooth) and Zigbee, etc., to meet the wireless connection requirements in different application scenarios.
Wallys has over  10 years of research and development experience, experienced in linux, wifi protocol and other aspects, Qualcomm chip development drivers, kernel and other important software development, modification and compilation, to meet customers' different wifi functional needs.
Email:sales@wallystech.com
WEB:Wallys 802.11ax, wifi 6, IPQ4029,IPQ4019,IPQ6018,IPQ6000.Router board, wireless card.Access Point.
GMT+8, 2026-11-3 11:28 , Processed in 0.028355 second(s), 10 queries , Gzip On, Redis On.
