查看: 2411|回复: 0
[供应] QCA9880 QCA9882 What’s the difference?|802.11ac Qualcomm Atheros Network ca...
发表于 2023-8-21 13:51:16 | 显示全部楼层 |阅读模式
QCA9880 QCA9882 What’s the difference?|802.11ac Qualcomm Atheros Network card Wallys
The Qualcomm Atheros QCA9880 s a highly integrated wireless local area network (WLAN) system-on-chip (SoC) for 5 GHz 802.11ac or 2.4/5 GHz 802.11n WLAN applications. The QCA9880 integrates an on-board CPU for low-level setup of WLAN physical layer (PHY) and RF to offload the host processor for other tasks. It enables high-performance 3x3 MIMO with three spatial streams for wireless applications demanding the highest robust link quality and maximum throughput and range. The QCA9880 integrates a multi-protocol MAC, PHY, analog-to-digital/digital-to-analog converters (ADC/DAC), 3x3 MIMO radio transceivers, and PCI Express interface in an all-CMOS device for low power consumption and small form-factor applications.
The QCA9880 implements half-duplex OFDM, CCK, and DSSS PHY, supporting 1.3 GBps for 802.11ac 80 MHz channel operation. It supports 802.11n up to 216.7 Mbps for 20 MHz and 450 Mbps for 40 MHz channel operations, and IEEE 802.11a/b/g data rates. Additional features include Maximal Likelihood (ML) decoding, Low-Density Parity Check (LDPC), Maximal Ratio Combining (MRC), Space Time Block Code (STBC), and On-Chip One-Time Programmable (OTP) memory to eliminate the need for an external flash and to further reduce the external component count and BOM cost. The QCA9880 supports 802.11 wireless MAC protocol, 802.11i security, Rx/Tx filtering, error recovery, and 802.11e quality of service (QoS).
QCA9880 and QCA9882 are both Wi-Fi chipsets manufactured by Qualcomm Atheros. The main difference between the two lies in their capabilities and features. Here's a comparison:
1. Wi-Fi Standards: Both chipsets support the 802.11ac Wi-Fi standard.
2.Spatial Streams: The QCA9880 supports up to 3 spatial streams, while the QCA9882 supports up to 2 spatial streams. Spatial streams refer to the number of independent data streams that can be transmitted and received simultaneously, affecting overall data throughput.
3.Channel Width: Both chipsets support channel widths up to 80 MHz. Wider channel widths can provide higher data rates but may require more spectrum availability.
It's important to note that specific features and capabilities may vary depending on the implementation and firmware of the chipset. It's recommended to refer to the official documentation or datasheets provided by Qualcomm Atheros for more details.
QCA9880 802.11ac Dual Band Module 3x3 2x2 2.4G 5G
DR900VX
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
FCC,CE and IC Certification
DR600VX
2.4GHz max 24dBm & 5GHz max 23dBm output power
IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n
2x2 MIMO Technology, up to 867Mbps
Support the Frequency 4920MHz~4980MHz
(LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
QCA9882 2x2 5G 802.11AC 802.11AN WiFi Module
DR882
Featuring with industrial-grade Atheros’s QCA9882 chipset
Integrated with 2x 2 5G high power Radio Card
4.940GHz to 5.825GHz Frequency Range
2 x 5G MMCX Connectors
20MHz/40MHz/80MHz Bandwidth
Support 802. 11AC/AN
Here is a comparison of the data rates and coverage for the DR900VX, DR600VX, and QCA9882 DR882 modules:
DR900VX:
Data Rates: Up to 1.3Gbps
Coverage: Reliable coverage with extended range and improved signal strength due to 3x3 MIMO technology and high output power.
DR600VX:
Data Rates: Up to 867Mbps
Coverage: Reliable coverage suitable for most standard-sized environments.
QCA9882 DR882:
Data Rates: Comparable to DR600VX (up to 867Mbps)
Coverage: Extended coverage and improved signal strength due to the high-power radio card.
Overall, the DR900VX offers the highest data rates, making it suitable for applications requiring fast and high-bandwidth connectivity. The DR600VX and QCA9882 DR882 modules offer slightly lower data rates but still provide reliable performance for most common wireless networking needs. The coverage of all three modules is generally satisfactory, with the DR900VX and DR882 offering extended coverage capabilities due to their specific features.
For more detailed information or specific technical specifications, I recommend reaching out to Wallys directly through their provided contact information.
GMT+8, 2026-11-23 09:17 , Processed in 0.030769 second(s), 8 queries , Gzip On, Redis On.
