查看: 10776|回复: 6
[QCC5系列] QCC5144固件.xuv格式,可以直接烧录使用
签到总天数:226天
签到总奖励:8396金币
发表于 2023-11-8 14:43:23 | 显示全部楼层 |阅读模式
发表于 2023-11-10 07:50:33 | 显示全部楼层
details of the FW, like it is ear bud / headset / ?
button details vol+ -,
led pins
function of buttons, else it will difficult to others to just go for it
签到总天数:226天
签到总奖励:8396金币
 楼主| 发表于 2023-11-10 08:09:40 | 显示全部楼层
headset
发表于 2023-11-10 12:47:59 | 显示全部楼层
led pins
function of buttons, else it will be difficult to others to just go for it ?
like from
https://www.52bluetooth.com/foru ... &extra=page%3D2
1. Based on the default source project (r00073 version) without modification
2. Press and hold the sysctrl button for 3 seconds to pair, press and hold for 6 seconds to clear the pairing list, short press to connect and disconnect audio
3. Supports USB audio sources and analog audio sources by default. The analog insertion detection port is PIO5 (insert low level), aux insertion priority
4. If the connection cannot be made, calibrate the frequency
5. If burned into qcc3050, A2DP has no sound, HFP sound is normal
6. Use 64M FLASH setting (according to the firmware size Judgment, minimum support 16M)
Note: calibration is required, otherwise the connection may fail or freeze. SBC aptx aptx-adaptive is supported by default.
签到总天数:64天
签到总奖励:2015金币
发表于 2023-11-13 11:11:51 | 显示全部楼层
学习
签到总天数:223天
签到总奖励:8338金币
发表于 2023-11-22 08:42:15 | 显示全部楼层
学习
发表于 2026-7-29 22:15:59 | 显示全部楼层
Thanks
GMT+8, 2026-10-23 01:42 , Processed in 0.021067 second(s), 14 queries , Gzip On, Redis On.
