查看: 2449|回复: 0
[供应] QCA9882, QCA9880, and MT7915 WiFi cards for OpenWrt:What are the difference?
发表于 2024-3-26 14:09:35 | 显示全部楼层 |阅读模式
In the realm of OpenWrt-compatible WiFi cards, selecting the right one can significantly impact your network's performance and reliability. Among the options available, the QCA9882, QCA9880, and MT7915 stand out as popular choices. In this article, we will delve into the differences between these WiFi cards to help you make an informed decision.
**QCA9882**
The QCA9882 WiFi card boasts a robust chipset designed to deliver exceptional performance. It supports various wireless standards, including WiFi 5 (802.11ac), ensuring compatibility with modern networks. Performance metrics such as throughput and range are commendable, making it suitable for demanding applications. QCA9882 is known for its seamless integration with OpenWrt, offering extensive configuration options and stability. While pricing may vary, it generally falls within a reasonable range, providing value for money.
**QCA9880**
Similar to the QCA9882, the QCA9880 WiFi card features a reliable chipset optimized for high-performance networking. It also supports WiFi 5 standards, guaranteeing compatibility with modern networks. Performance metrics are commendable, although specific benchmarks may vary. QCA9880 is well-supported by OpenWrt, offering users a plethora of configuration options and stability. Pricing for the QCA9880 is competitive, making it an attractive choice for budget-conscious consumers seeking reliable performance.
**MT7915**
The MT7915 WiFi card is another contender in the OpenWrt ecosystem, boasting a chipset designed to deliver robust performance. It supports WiFi 6 (802.11ax) standards, offering enhanced throughput and efficiency compared to its predecessors. Performance metrics such as throughput and latency are impressive, catering to demanding networking requirements. While OpenWrt compatibility may vary, efforts are underway to ensure seamless integration with the platform. Pricing for the MT7915 tends to be higher compared to WiFi 5 alternatives, reflecting its advanced features and capabilities.
Wallys Modules and Platform
DR882 (QCA9882):
Chipset: Atheros QCA9882
2x2 5G high-power radio card
Frequency range: 4.940GHz to 5.825GHz
2x 5G MMCX connectors
Bandwidth: 20MHz/40MHz/80MHz
Supports 802.11ac/an standards
RoHS compliant
DR900VX
Chipset: Qualcomm-Atheros QCA9880
Output power: 2.4GHz max 26dBm, 5GHz max 25dBm
IEEE 802.11a/b/g/n/ac compliant and backward compatible
3x3 MIMO technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliant
Supports various technologies and IEEE standards (e.g., spatial multiplexing, LDPC codes, MRC, STBC, DFS)
FCC, CE, and IC certification
DR600VX
Output power: 2.4GHz max 24dBm, 5GHz max 23dBm
IEEE 802.11a/b/g/n compliant and backward compatible
2x2 MIMO technology, up to 867Mbps
Frequency support: 4920MHz~4980MHz
RoHS compliant
FCC, CE certification
DR7915
Chipset: MT7915+MT7975
Host Interface: Mini PCI Express 2.1
Antenna Connector: 2 x UF.L
Frequency Range: 2.4GHz: 2.412GHz to 2.472GHz, 5GHz: 5.180GHz to 5.825GHz
Operating Voltage: 3.3V DC
Power Consumption: 4-8w
Modulation Techniques: OFDM: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM
Environmental Temperature: Operating: -40°C to 70°C, Storage: -40°C to 90°C
Environmental Humidity, non-condensing: Operating: 5% to 95%, Storage: Max. 90%
ROHS Compliance: YES
Dimensions (W×H×D): 51mm × 30mm × 5.8mm
Click below the link for more information of DR7915
PlatformR4019
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Support Openwifi
Support QSDK
Support Openwrt
Feel free to share your thoughts on QCA9882, QCA9880, and MT7915 WiFi cards for OpenWrt in the comments section below.
Wallys is committed to continuous innovation, pushing the boundaries of WiFi technology. Alongside hardware products, Wallys offers ODM/OEM services, including customization to tailor WiFi 6 products and embedded boards to your specific needs, along with engineering support, testing, and certification.
For inquiries or to discuss your requirements, contact our dedicated sales team at sales1@wallystech.com.
Wallys - Empowering Connectivity, Driving Innovation.
GMT+8, 2026-11-3 13:03 , Processed in 0.031823 second(s), 8 queries , Gzip On, Redis On.
