查看: 2080|回复: 0
[供应] IPQ5018 Router and QCN9074 Card: Unleashing Ultra-Fast and Stable WiFi 6E Networ
发表于 2024-4-11 14:50:04 | 显示全部楼层 |阅读模式
IPQ5018 Router and QCN9074 Card: Unleashing Ultra-Fast and Stable WiFi 6E Network
Experience the Power of WiFi 6E with IPQ5018 Router and QCN9074 Card Duo
Get ready to experience unparalleled speed and stability with the IPQ5018 Router and QCN9074 Card duo. Designed for high-performance wireless networking, the IPQ5018 boasts integrated 802.11ax Wi-Fi/Bluetooth 5.1 subsystems, delivering cost-effective and efficient connectivity.
IPQ5018
The IPQ5018 is a highly integrated System-on-Chip (SoC) designed and manufactured for high-performance and efficient wireless network applications, including home routers, mesh nodes, and gateways. It features integrated 802.11ax Wi-Fi/Bluetooth 5.1 subsystems, providing high efficiency and cost-effectiveness.
Key Features:
- Wi-Fi subsystem supports IEEE802.11ax, incorporating a wireless radio operating in the 2.4 GHz band with 2 antennas (2x2/40).
- Network subsystem:
  - Low-power PCIe interface with L1 sub-states.
  - Two Ethernet ports:
    - One integrated GbE PHY.
    - One SerDes supporting 3.125/1.25 Gbps Ethernet ports for external 2.5/1 GbE PHY. This SerDes operates in SGMII+ or SGMII mode to connect to 2.5 GbE PHY or single-port GbE PHY.
In today's fast-paced digital world, a reliable and lightning-fast internet connection is essential for seamless connectivity. With the advent of WiFi 6E technology, users can now enjoy unprecedented speed, stability, and coverage. The combination of the IPQ5018 Router and QCN9074 Card delivers an unparalleled WiFi 6E experience, setting new standards for home and business networks.
The IPQ5018 Router is a powerhouse in the world of networking, equipped with advanced features and cutting-edge technology to provide ultra-fast and stable connectivity. Its robust hardware ensures maximum performance, while its intelligent software optimizes network traffic for an uninterrupted online experience.
Paired with the QCN9074 Card, this duo takes WiFi 6E to new heights. The QCN9074 Card is designed to maximize the capabilities of WiFi 6E, offering higher speeds, lower latency, and increased capacity compared to previous generations. With its advanced beamforming and MU-MIMO technology, the QCN9074 Card ensures optimal signal strength and coverage throughout your home or office.
Together, the IPQ5018 Router and QCN9074 Card create a WiFi 6E network that is not only blazing fast but also incredibly stable. Whether you're streaming 4K videos, gaming online, or video conferencing with colleagues, you can count on a seamless and lag-free experience.
But the benefits don't stop there. The IPQ5018 Router and QCN9074 Card also prioritize security, with robust encryption protocols and built-in firewalls to protect your network from cyber threats. Additionally, advanced parental controls and network management tools allow you to customize and monitor your network with ease.
In conclusion, the IPQ5018 Router and QCN9074 Card combination is the ultimate solution for those seeking a high-performance WiFi 6E network. Experience the future of connectivity today with unparalleled speed, stability, and coverage.
DR5018
DR5018 based on IPQ5018 chipset is an enterprise wireless module integrated with BT5.1 Radio module and 2x2 2.4G high power Radio module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment.
CPU: Qualcomm-Atheros IPQ5018
CPU Frequency: Dual-core ARM 64-bit A53 @1.0 GHz processor
System Memory: 512MB DDR3L 16-bit interface with 32-bit memory bus design (Optional support for 1G)
Ethernet Port: 4 x 1Gbps Ethernet Ports or 1 x 1Gbps Ethernet Port & PoE
NGFF Slot: M.2 Card Slot for 5G (QUECTEL RM 500Q-GL); M.2 Card Slot for QCN9074 WIFI 6E Card
PoE: Support
DC Jack: 12V power supply
LED Header: LED for power, WiFi strength
Serial Port: Support
Wireless: On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain; 2x IPEX Connectors
Bluetooth: BT5.1 (optional)
Nor Flash: 8MB
Nand Flash: 128 MB
DDR: 512MB
Dimension: 170mm x 120mm x 15mm
DR9074
Chipset: Qualcomm Atheros QCN9074
WLAN Host Interface: PCI Express 3.0 Interface
System Memory: 2Mbit serial I²C bus EEPROM
Standard Operating Voltage: 5V
Operating Systems: QSDK
Host Interface: M.2 E Key
Antenna Cable / Port: 4 x MMCX Connectors, 4T4R
Frequency Range: 5.925GHz-7.125GHz
Data Rates: 6GHz, max 23dBm per chain, up to 4804Mbps
Channel Spectrum Widths: Support 20/40/80/160MHz at 6GHz
Modulation Techniques: OFDMA: BPSK, QPSK, DBPSK, DQPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Temperature Range: Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity: Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification: TBD
Power Consumption: TBD
Reference Design: PN02.7
Dimensions (WxHxD): 57mm x 63mm x 6mm
For inquiries or to discuss your specific requirements, please contact our dedicated sales team at sales1@wallystech.com.
Wallys - Empowering Connectivity, Driving Innovation.
GMT+8, 2026-10-23 04:37 , Processed in 0.022849 second(s), 8 queries , Gzip On, Redis On.
