查看: 1858|回复: 0
[供应] Wallys DR5018: Dependable WiFi 6 Routerboard for Long-Distance PTP Transmission
发表于 2024-6-7 13:28:13 | 显示全部楼层 |阅读模式
Wallys DR5018: Dependable WiFi 6 Routerboard for Long-Distance PTP Transmission with WPA3 SecurityIn today’s industrial environments, reliable long-distance wireless communication is crucial. Whether it’s for factory automation, smart warehousing, or remote monitoring and control, stable and efficient Point-to-Point (PTP) wireless transmission is essential. Wallys' DR5018 WiFi 6 Routerboard, with WPA3 encryption and exceptional PTP transmission performance, is an ideal solution for industrial long-distance communication. Powered by the robust IPQ5018 processor, the DR5018 ensures strong performance and reliability.
DR5018's PTP Transmission PerformanceThe Wallys DR5018 excels in PTP long-distance transmission on both the 5GHz and 6GHz bands. Here are the performance results from various distance tests:
3.3KM PTP Test (DR5018M)
  • 5GHz: 949Mbps
  • 6GHz: 821Mbps
1.5KM PTP Test (DR5018M)
  • 5GHz: 1.5Gbps
  • 6GHz: 1Gbps
These impressive results demonstrate that the DR5018 can maintain high bandwidth and stable connections over long distances, making it ideal for a wide range of industrial applications.
IPQ5018 ProcessorThe DR5018 features Qualcomm’s IPQ5018 processor, designed for high performance and efficiency, offering several advantages:
1. High Processing PowerThe IPQ5018 processor boasts a quad-core ARM Cortex-A7 architecture with a clock speed of up to 1.0GHz, efficiently handling numerous concurrent connections and data transmissions to ensure network stability and responsiveness.
2. Advanced Network AccelerationIntegrated with Qualcomm’s network acceleration technology, the IPQ5018 significantly enhances network throughput and data processing efficiency, ensuring exceptional performance even under heavy load.
3. WiFi 6 Standard SupportSupporting the WiFi 6 (802.11ax) standard, the IPQ5018 incorporates advanced technologies such as OFDMA, MU-MIMO, and 1024-QAM modulation, delivering higher speeds, lower latency, and stronger signal coverage.
4. Energy EfficiencyThe IPQ5018 offers outstanding energy efficiency, delivering powerful performance while maintaining low power consumption, making it ideal for energy-sensitive industrial environments.
Benefits of WiFi 6WiFi 6 (802.11ax) brings several advancements that make the DR5018 perform exceptionally well in industrial settings:
1. Increased Speed and BandwidthWiFi 6 provides higher data transfer rates and greater bandwidth, supporting high-throughput industrial applications such as HD video surveillance and big data transmission.
2. Reduced LatencyWiFi 6’s low latency ensures timely responses for industrial automation and real-time control applications, enhancing operational efficiency and accuracy.
3. Enhanced Device Density SupportWiFi 6 utilizes OFDMA (Orthogonal Frequency Division Multiple Access) technology, allowing multiple devices to transmit data simultaneously, significantly improving network efficiency and capacity. This is crucial in device-dense industrial environments.
4. Superior Signal CoverageWiFi 6 delivers stronger signal coverage, ensuring stable network connections throughout large factories or warehouse facilities.
Security with WPA3 EncryptionThe DR5018 supports WPA3 encryption, providing top-tier security for industrial networks. Compared to WPA2, WPA3 offers several enhancements:
1. Robust Encryption AlgorithmsWPA3 uses more robust encryption algorithms, delivering higher security and ensuring data safety during transmission.
2. Protection Against Man-in-the-Middle AttacksWPA3 enhances authentication mechanisms to effectively prevent Man-in-the-Middle (MitM) attacks, ensuring data integrity and confidentiality in industrial environments.
3. Secure Public Network ConnectionsWPA3 includes Individualized Data Encryption, ensuring that each device’s communication is independently encrypted, even on public networks, enhancing security.
4. Simplified Device ConfigurationWPA3 simplifies device configuration and connection processes, allowing industrial devices to securely and quickly join the network, reducing configuration errors.
Industrial Applications of DR5018With its powerful PTP transmission capabilities and advanced encryption technologies, the DR5018 Routerboard is suitable for various industrial applications:
1. Factory AutomationIn automated production lines, the DR5018 provides efficient and stable wireless connections, supporting real-time data transmission and device control, boosting production efficiency and accuracy.
2. Smart WarehousingIn smart warehousing systems, the DR5018 supports large-scale device concurrent connections and data transmissions, ensuring efficient and precise warehouse operations.
3. Industrial SurveillanceIn industrial surveillance systems, the DR5018 offers low-latency and highly reliable wireless connections, supporting HD video transmission and real-time monitoring, ensuring production safety.
4. Remote Operation and ControlFor applications requiring remote operation and control, the DR5018 provides stable long-distance wireless connections, ensuring operational accuracy and real-time response.
ConclusionWallys' DR5018 WiFi 6 Routerboard, with WPA3 encryption, the powerful IPQ5018 processor, and excellent PTP transmission performance, provides comprehensive protection and reliability for industrial networks. Its outstanding performance and security features meet the needs of various industrial applications, ensuring safe data transmission and stable network connections.
Choosing Wallys DR5018 means selecting a wireless network solution that delivers optimal performance and top-tier security for industrial environments. Whether it’s data transmission, device connectivity, real-time monitoring, or control, the DR5018 meets your needs and becomes a reliable partner in building your industrial network.
For more information, please contact us at [url=]sales1@wallystech.com[/url].
GMT+8, 2026-10-26 18:24 , Processed in 0.017841 second(s), 8 queries , Gzip On, Redis On.
