查看: 1606|回复: 0
[供应] Peacock: The Ultimate Industrial-Grade WiFi 6 Dual-Band Wireless Bridge - AVAILA
发表于 2024-7-11 16:08:29 | 显示全部楼层 |阅读模式
Introducing Wallys' Peacock: The Ultimate Industrial-Grade WiFi 6 Dual-Band Wireless Bridge - AVAILABLE NOW
Wallys Communications is proud to unveil Peacock, our latest innovation in industrial-grade WiFi 6 technology. Designed specifically for vehicle-mounted applications, Peacock offers unparalleled performance and reliability for warehouse AGV (Automated Guided Vehicle) transport needs. Let's delve into the features and specifications that make Peacock an exceptional solution for seamless and robust wireless communication.
High-Performance Specifications
Peacock is equipped with cutting-edge technology to ensure optimal performance in demanding industrial environments. Here’s a detailed look at its specifications:
  • CPU: Quad-core ARM 64-bit A53 @ 1.8 GHz processor.
  • Wireless: Supports on-board 802.11 b/g/n/ax 2x2 MU-MIMO OFDMA at 2.4GHz and 5GHz, with a maximum output of 27dBm per chain.
  • Dimension: Compact size of 135mm x 45mm x 130mm (without antenna) and an antenna length of 210mm.
  • USB/Header: 1x USB 3.0 for flexible connectivity.
  • POE Options:
    • Option 1: 48V~56V passive POE/Active POE (supports 802.3 at)
    • Option 2: 24V~48V passive POE
  • DC Jack: 24V~48V power supply.
  • Ethernet Ports: 1 x 1Gbps Ethernet Port & POE, 1 x 1Gbps Ethernet Port.
  • Memory: 8MB Nor Flash and 256MB Nand Flash.
Functional Characteristics
Peacock is built to handle the most challenging environments with features designed to ensure seamless and reliable connectivity:
  • Protocol Support: Compatible with 802.11 b/g/n/ax protocols.
  • Bandwidth: Max bandwidth up to 1201 Mbps and dual-band concurrent max bandwidth of 1800 Mbps.
  • Fast Roaming: Supports 802.11r fast roaming for uninterrupted connectivity.
  • Frequency Support: Operates within the 5180~5850 MHz range, supporting multi-country frequency roaming.
  • Long-Range Protocol: In-house developed special long-range protocol enhances transmission distance significantly.
  • Fast Switching: Designed for vehicle and marine use with fast switching capabilities.
  • Dynamic Frequency Selection (DFS): Ensures optimal frequency usage for minimal interference.
Product Features
Peacock stands out with its robust and user-friendly features:
  • External High-Performance Antennas: Ensure superior signal strength and range.
  • Secure Slide Rail Mounting Design: Provides a secure and easy-to-install solution for various environments.
  • ≤50ms Fast Switching: Guarantees minimal downtime and high reliability for moving vehicles.
Applications
Peacock is versatile and adaptable, making it ideal for several industrial applications:
  • Smart Logistics: Enhances warehouse operations by ensuring seamless communication for AGVs and other automated systems.
  • Mining Projects: Provides reliable connectivity in challenging environments, ensuring continuous operation of mining equipment.
Equipped with 4 external antennas, Peacock is optimized for transmitting and covering fixed locations within a 2 km range, making it a perfect choice for logistics warehouses, parking lots, maintenance yards, subway stations, and similar environments. When paired with Wallys omni-directional antennas, Peacock enables versatile application across various scenarios.
Conclusion
Wallys’ Peacock is not just a product; it is a solution that ensures high performance, high bandwidth, and ultra-fast roaming tailored for transportation and industrial use. Its advanced features and robust design make it an essential tool for enhancing operational efficiency and ensuring seamless connectivity in any industrial setting.
AVAILABLE NOW – For more information, visit our website at WallysTech or contact our sales team for detailed specifications and purchasing options. Spread your wings with seamless roaming and elevate your industrial operations with Peacock!
Email:sales1@wallystech.com
GMT+8, 2026-4-1 00:44 , Processed in 0.069524 second(s), 9 queries , Gzip On, MemCached On.
