查看: 12827|回复: 0
[供应] IPQ9574: Does Wallystech's DR9574 Powered by Qualcomm IPQ9574 Support MLO?
发表于 2024-9-29 14:48:39 | 显示全部楼层 |阅读模式
Wallystech Wi-Fi 7 Router Powered by Qualcomm IPQ9574 and QCN9274: Enhanced Network Experience with MLO Technology
MLO (Multi-Link Operation) is a key technology in Wi-Fi 7 that allows data to be transmitted across multiple wireless links simultaneously, significantly improving network performance, stability, and efficiency. Specifically, MLO enables devices to transmit and receive data on multiple frequency bands (2.4GHz, 5GHz, and 6GHz) at the same time, rather than being limited to a single band.
Key Roles of MLO in Wi-Fi 7:
  • Increased Throughput: MLO allows devices to utilize multiple links for data transmission, greatly boosting bandwidth and data transfer speeds, especially for high-bandwidth applications like 4K/8K streaming, cloud gaming, and VR/AR.
  • Reduced Latency: Parallel transmission across multiple links accelerates data transfer, lowering latency, which is crucial for real-time applications like online gaming and video conferencing.
  • Enhanced Reliability: MLO can automatically switch to other links if one experiences interference or congestion, ensuring connection stability, especially in crowded environments or when devices are far from the router.
  • More Efficient Spectrum Usage: MLO dynamically distributes traffic across different links, improving spectrum resource utilization and reducing wireless congestion.
Why Many Applications Need MLO:
  • High Bandwidth Demands: As 4K/8K video and immersive media become more prevalent, applications increasingly require higher bandwidth. MLO's multi-link capability meets these demands.
  • Low Latency Requirements: Applications like cloud gaming and video conferencing require very low latency. MLO can significantly reduce latency through parallel transmission.
  • Reliability: Smart home and industrial automation applications need stable connections. MLO's multi-link mechanism ensures stability even if one link fails.
About IPQ9574 and QCN9274:
  • Qualcomm IPQ9574: This powerful SoC (System on Chip) is designed for high-performance networking applications, providing robust processing power and advanced features to support next-gen Wi-Fi 7 capabilities. Its architecture is optimized for handling multiple data streams, ensuring seamless connectivity and improved network efficiency.
  • Qualcomm QCN9274: Qualcomm Wi-Fi 7 'Waikiki' series radio solution.
In summary, MLO is a core technology in Wi-Fi 7 that enhances network experience by providing higher throughput, lower latency, and greater reliability, making it essential for modern high-performance applications.
Wallystech's Solution:
Wallystech's Wi-Fi 7 router DR9574 supports MLO functionality with the DR9274 Wi-Fi 7 card, fulfilling diverse Wi-Fi project needs:
  • DR9574 supports 3 DR9274 single cards: 2.4G, 5G, and 6G can operate simultaneously.
  • DR9574 supports one DBDC card: DR9274-5G6G.
[color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]https://www.wallystech.com/Network_Card/DR9274-5G6G-wifi7-card-moulde-Qualcomm-QCN9274-M.2-Slot-2x2-5G-2x2-6G-dual-band-Wallys.html
For more information or project inquiries, please feel free to contact us at: [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]sales1@wallystech.com.
GMT+8, 2026-10-24 02:19 , Processed in 0.020620 second(s), 8 queries , Gzip On, Redis On.
