查看: 894|回复: 0
[供应] The incredibly powerful AP Controller has evolved again! It's even better than b
发表于 2025-1-22 11:35:33 | 显示全部楼层 |阅读模式
For those serious about industrial network management, the Wallys AP Controller has always been a reliable tool. However, as with any great software, there are constant improvements and updates, and this latest version is no exception. After facing some common issues that are often seen with less durable solutions, Wallys AP Controller has evolved, and it's now better than ever!
Let’s take a deeper look at what’s new, and why this tool should be your go-to for seamless network management.
What's New in This Version of Wallys AP Controller?
Wallys AP Controller has evolved to include essential features that will transform how you manage your network, especially in large environments like factories or campuses.
  • Group Management Functionality: The new version introduces group management features, allowing you to organize and manage AP devices across different network segments. Imagine you’re managing a large factory where the warehouse and office building are on separate subnets. Previously, the AP controller could only manage one subnet per instance, but now, you can seamlessly handle devices across multiple network segments from a single interface.
  • Batch Settings and Categorization: With the group management feature, you can now batch set notes for your AP devices. These notes help you categorize devices based on their location or function, making it easy to filter and manage them accordingly. This means you can quickly find and apply settings to a specific group of devices, whether it’s for firmware upgrades, Wi-Fi configurations, or other tasks.
Batch Configure Equipment Notes
Building A
Building B
Warehouse
  • Batch Firmware Upgrades: The batch firmware upgrade feature has been enhanced, enabling you to upgrade the firmware of multiple devices at once, saving you time and ensuring consistency across your network.
  • Wi-Fi Configuration: Now, you can batch configure Wi-Fi settings, including SSIDs and security protocols, across different groups of devices, making network setup and management even more efficient.
Wi-Fi Configuration
  • Bulk Command Execution: A standout feature of this update is the bulk command execution capability. This new feature is incredibly useful when troubleshooting or debugging. For example, you can select multiple devices and issue commands to make their LEDs flash, helping you quickly identify and isolate devices that might not be functioning properly. This makes network issues much more visual and easier to diagnose.
What Can You Manage with Wallys AP Controller?
With the Wallys AP Controller, you can manage a variety of tasks to keep your network running smoothly:
  • Upgrading Device Firmware: Keep all your devices up to date with the latest firmware, ensuring optimal performance and security across your entire network.
  • Configure Wi-Fi: Easily configure Wi-Fi settings across all connected devices, including SSID, security protocols, and bandwidth management for optimal performance.
  • Deleting Offline Devices: Remove offline or inactive devices from your network to maintain efficiency and ensure only active devices are consuming resources.
  • Update Equipment Notes: Add or update equipment notes for each device to track changes, configurations, or any specific requirements for your network management.
  • Importing Whitelist: Import a whitelist of authorized devices to prevent unauthorized access and keep your network secure.
  • Execute Commands: Execute custom commands across multiple devices simultaneously to streamline tasks like troubleshooting, configuration changes, or system resets.
Why Choose Wallys AP Controller?
The Wallys AP Controller has become a truly powerful tool for managing large-scale, multi-segment networks. With new features like group management, batch firmware upgrades, Wi-Fi configuration, and bulk command execution, it’s never been easier to keep your network in check.
If you're managing a large facility or complex network, this upgraded Wallys AP Controller is the ideal solution to streamline your tasks and make troubleshooting easier.
For project inquiries or to schedule a sample test, contact our sales team at [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]sales1@wallystech.com. We're here to help you tailor the perfect solution for your needs.
Two Version for Option
WL-AC1000-E
WL-AC1000-1U
GMT+8, 2026-10-30 07:41 , Processed in 0.020160 second(s), 9 queries , Gzip On, Redis On.
