查看: 283|回复: 0
[音频] ES8375高性能单声道音频解码说明书
发表于 2025-2-25 11:20:56 | 显示全部楼层 |阅读模式
ES8375高性能单声道音频解码说明书
System
• High performance and low power multi-bit delta-sigma audio ADC and DAC
• I2S/PCM master or slave serial data port
• 256/384Fs and USB 12/24 MHz audio system clocks
• I2C interface
Mono ADC
• 24-bit, 8 to 96 kHz sampling frequency
• 101 dB signal to noise ratio, -90 dB THD+N
• One pair of analog input with differential input option
• Low noise pre-amplifier
• Support analog and digital microphone
Mono Digital Class D
• 8 to 96 kHz sampling frequency
• 102 dB signal to noise ratio
1.25W@4Ω
• Over current and temperature protection
• Pop and click noise suppression
Low Power
• 1.8V to 3.3V operation
• mW playback and record
• Low standby current
APPLICATIONS
• CAT1
• Camera
• General Purpose
ORDERING INFORMATION
ES8375 -40°C ~ +125°C
3x3 QFN-20
详细设计指南请联系 李工 18938047300
GMT+8, 2025-6-2 21:20 , Processed in 0.125520 second(s), 13 queries , Gzip On, MemCached On.
