查看: 178|回复: 0
[供应] QCN9024 WiFi 6 Tri-Band Card: High-Speed Connectivity for Modern Networks
发表于 2025-3-21 14:40:20 | 显示全部楼层 |阅读模式
WallysTech DR9074-TRIABDN: High-Performance WiFi 6 Tri-Band Network Card for Next-Gen Wireless SolutionsIntroduction
With the increasing demand for high-speed wireless networks, WiFi 6 technology has become the preferred choice for upgrading enterprise and industrial wireless solutions. Offering higher throughput, lower latency, and superior interference resistance, WiFi 6 enables seamless connectivity across multiple applications.
WallysTech introduces the DR9074-TRIABDN, a high-performance WiFi 6 tri-band network card powered by the Qualcomm [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]QCN9024 chipset. Supporting 2.4GHz, 5GHz, and 6GHz frequency bands, this card is designed for high-density environments, multi-device connectivity, and low-latency applications. This article will explore the technical features, application scenarios, and benefits of the DR9074-TRIABDN in upgrading wireless network solutions.
DR9074-TRIABDN Specifications
WallysTech DR9074-TRIABDN is built on the Qualcomm QCN9024 chipset and boasts the following core specifications:
Parameter Specification Chipset Qualcomm QCN9024 WiFi Standard 802.11ax (WiFi 6) Frequency Bands 2.4GHz / 5GHz / 6GHz Antenna Interface 4x4 MU-MIMO Throughput 2.4GHz: 1148 Mbps ;5GHz: 2402 Mbps ;6GHz: 2402 Mbps Interface PCIe 3.0 Transmit Power Up to 23dBm Security WPA3 Encryption Compatibility Supports OpenWRT / Linux / Custom Firmware
Advantages of a Tri-Band WiFi Design
One of the standout features of the DR9074-TRIABDN is its tri-band support (2.4GHz, 5GHz, 6GHz). Compared to traditional single-band or dual-band network cards, it provides higher throughput, reduced interference, and more flexible networking options.
1. 2.4GHz Band: Wide Coverage, Ideal for IoT Devices
  • Advantages: Strong penetration capability, suitable for long-distance connections.
  • Applications: Smart home devices, industrial sensors, low-power IoT devices.
2. 5GHz Band: High Throughput for Mainstream Wireless Applications
  • Advantages: Supports higher bandwidth while avoiding congestion in the 2.4GHz band.
  • Applications: Enterprise WiFi networks, HD video streaming, cloud computing offices.
3. 6GHz Band: Low-Interference, High-Speed Wireless Connectivity
  • Advantages: Offers higher bandwidth and less interference, meeting the needs of WiFi 6E devices.
  • Applications: VR/AR, low-latency cloud gaming, high-speed wireless backhaul.
With tri-band operation, the DR9074-TRIABDN can support multiple use cases simultaneously, optimizing network performance and reducing interference.
Qualcomm QCN9024: The Power Behind WiFi 6
As the core of the DR9074-TRIABDN, the QCN9024 chipset from Qualcomm is a flagship WiFi 6 solution offering:
✅ 4x4 MU-MIMO – Enables simultaneous multi-user transmissions, improving throughput and network efficiency. ✅ OFDMA (Orthogonal Frequency Division Multiple Access) – Efficient data scheduling, reducing network latency. ✅ BSS Coloring Technology – Reduces co-channel interference, enhancing network stability. ✅ TWT (Target Wake Time) – Reduces power consumption, extending the battery life of IoT devices. ✅ WPA3 Security – Provides enhanced wireless security for modern network environments.
Application Scenarios and Industry Benefits
The DR9074-TRIABDN is well-suited for enterprise WiFi, industrial IoT, wireless Mesh networks, and dedicated wireless systems.
1. Enterprise-Grade Wireless AP / WiFi Solutions
  • High-concurrency WiFi connectivity for office environments.
  • OFDMA & MU-MIMO improve multi-device performance.
  • 6GHz support reduces interference, ensuring a fast and reliable WiFi experience.
2. Industrial IoT (IIoT) & Smart Cities
  • 2.4GHz for IoT device connections, ideal for long-range, low-power sensors.
  • 5GHz/6GHz for industrial data transmission, supporting smart factories and remote monitoring.
  • TWT technology extends the battery life of IoT sensors and edge devices.
3. High-Performance Mesh & Backhaul Networks
  • 6GHz as a dedicated backhaul frequency, enhancing mesh WiFi efficiency.
  • Compatible with BATMAN and other mesh networking protocols, optimizing multi-hop routing.
4. Wireless HD Video & Low-Latency Gaming
  • WiFi 6 + 6GHz low-interference connectivity for smooth 4K/8K video streaming.
  • Ultra-low latency for cloud gaming and VR/AR applications.
Comparison with Other WiFi 6 Network Cards
Parameter Wallys DR9074-TRIABDN Competitor A Competitor B
WiFi Standard WiFi 6 (802.11ax) WiFi 6 WiFi 5
Frequency Bands 2.4G / 5G / 6G 2.4G / 5G 5G
MU-MIMO 4x4 2x2 2x2
Max Throughput 2402 Mbps (5G/6G) 1733 Mbps (5G) 1300 Mbps (5G)
BSS Coloring ✅ Supported ❌ Not Supported ❌ Not Supported
TWT Power Saving ✅ Supported ❌ Not Supported ❌ Not Supported
WPA3 Security ✅ Supported ❌ Not Supported ❌ Not Supported
As seen in the comparison, DR9074-TRIABDN offers superior performance, broader frequency options, less interference, and enhanced security, making it a leading WiFi 6 solution.
Why Choose WallysTech DR9074-TRIABDN?
✅ Tri-band WiFi 6 support – 2.4G / 5G / 6G compatibility for diverse applications. ✅ Powered by Qualcomm QCN9024 – 4x4 MU-MIMO for ultra-fast, stable connections. ✅ OFDMA & BSS Coloring – Increases network efficiency and reduces congestion. ✅ Advanced WPA3 security – Ideal for enterprise and industrial wireless deployments. ✅ Mesh & Backhaul compatibility – Perfect for high-density WiFi installations.
The WallysTech DR9074-TRIABDN is designed for enterprises, industrial applications, smart cities, and high-performance wireless networking, bringing WiFi 6 capabilities to the next level.
Interested in DR9074-TRIABDN? Contact us today for more details and pricing!
[color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]sales1@wallystech.com
GMT+8, 2025-5-23 15:10 , Processed in 1.057606 second(s), 13 queries , Gzip On, MemCached On.
