查看: 501|回复: 0
[供应] IPQ5332 vs IPQ5018: Which Qualcomm Chipset Fits Your Next Wi-Fi Project?
发表于 2025-5-14 13:18:59 | 显示全部楼层 |阅读模式
Choosing between IPQ5332 and IPQ5018 comes down to one key question: Do you need Wi-Fi 7's cutting-edge features, or is Wi-Fi 6 efficiency sufficient for your deployment?
🔍 OverviewFeatureIPQ5018IPQ5332
Wi-Fi StandardWi-Fi 6Wi-Fi 7 (Draft)
CPUDual-core ARM Cortex-A53Quad-core ARM Cortex-A73
Max Spatial Streams2x22x2
MLO (Multi-Link Operation)❌✅
Throughput~1.8 Gbps~3.6 Gbps
Target UseCost-effective AP/CPEHigh-performance next-gen AP/router
📦 When to Choose IPQ5018
  • Great for Wi-Fi 6 routers, mesh nodes, IoT gateways
  • Ideal for cost-sensitive projects with stable performance
  • Recommended board: Wallys DR5018S
🚀 When to Choose IPQ5332
  • Built for next-gen Wi-Fi 7 networks
  • Supports MLO + wider 320MHz bandwidth
  • Ideal for enterprise-grade, latency-sensitive, or multi-client mesh deployments
  • Recommended board: Wallys DR5332
💼 Wallys: Full Stack Wireless Solution
We offer:
  • Complete router boards (IPQ5018 / IPQ5332 / IPQ8072 / IPQ9574)
  • Matched radio cards (QCN9074 / QCN9024 / MT7915)
  • Firmware pre-calibration (OpenWrt / QSDK / MLO)
  • Enclosure, PoE, antenna, and OEM customization
📨 Contact: [url=]sales1@wallystech.com[/url]
🌐 More info: www.wallystech.com
GMT+8, 2025-9-3 07:21 , Processed in 0.110367 second(s), 13 queries , Gzip On, MemCached On.
