查看: 253|回复: 0
[供应] DR5332 + QCN9274: Build Smarter, Faster WiFi 7 Networks with Wallys
发表于 2025-6-13 11:59:27 | 显示全部楼层 |阅读模式
WiFi 7 is more than just a speed upgrade — it’s a whole new architecture for wireless communication.
At Wallys, we’re proud to introduce the DR5332/DR5322S/DR5322 router board, a next-generation platform designed to help OEM/ODM clients harness the full power of WiFi 7 through modular flexibility, robust performance, and seamless customization.
🔍 What Is DR5332/DR5322?
The DR5332/DR5322 is based on the Qualcomm IPQ5332 / IPQ5322 SoC, a quad-core solution optimized for embedded wireless applications. It delivers:
  • ✅ Tri-band support: 2.4GHz / 5GHz / 6GHz
  • ✅ PCIe 3.0 slot for radio modules like QCN9274 and QCN6274
  • ✅ 2.5G Ethernet ports + 10G SFP for uplink/backhaul
  • ✅ 1GB DDR4 RAM + 8GB eMMC onboard
  • ✅ OpenWrt/QSDK firmware support
Whether you’re developing outdoor access points, industrial IoT gateways, or mesh nodes, DR5332 is a good choice.
📡 Paired with QCN9274/QCN6274 — WiFi 7 at Its Best
The DR5332 pairs perfectly with Wallys’ QCN9274 or QCN6274 modules to unlock full 802.11be WiFi 7 capabilities:
  • 📶 Up to 320 MHz channel bandwidth
  • 🔁 Multi-Link Operation (MLO)
  • 🧠 4x4 MU-MIMO
  • 🔧 Lower latency, higher throughput, improved spectrum efficiency
This makes it ideal for high-density deployments, long-range outdoor APs, or environments with heavy interference — such as factories, ports, or smart campuses.
💼 For Developers, Integrators, and Innovators
The DR5332 is designed with integrators in mind:
  • You can quickly adapt it to your own enclosure or ecosystem
  • Use your preferred WiFi 6/7 modules — backward compatibility ensured (e.g., QCN9024, QCN9074)
  • Add LTE/5G via M.2 expansion for hybrid connectivity
Need something special? Our team offers custom hardware/firmware integration services for high-volume OEMs.
📢 Upcoming Highlight: IPQ5424 Support
Our roadmap includes support for IPQ5424, Qualcomm’s newest ‘Marina’ series SoC. If you’re planning your next-gen product, we can help you future-proof.
📩 Looking to request a sample or technical manual?
Contact us: sales1@wallystech.com
🔗 Explore DR5332 and more:
https://www.wallystech.com/WiFi7_product/Wallys-wifi7-DR5322-IPQ5322-10G-SFP-1GB-DDR4-16-bit.html
#WiFi7 #QCN9274 #QCN6274 #IPQ5332 #DR5332 #WallysTech #RouterBoard #WirelessModules #IndustrialWiFi #OpenWrt #QSDK #OEM #ODM #CustomHardware #NetworkingInnovation
GMT+8, 2025-9-16 02:43 , Processed in 0.222487 second(s), 13 queries , Gzip On, MemCached On.
