查看: 743|回复: 0
[供应] QCN6274 vs QCN9024: Which Tri-Band Module Is Right for Your Next Wireless Projec
发表于 2025-7-2 10:46:44 | 显示全部楼层 |阅读模式
⚔️ QCN6274 vs QCN9024: Which Tri-Band Module Is Right for Your Next Wireless Project?
In the world of advanced Wi-Fi development, it's no longer just about choosing the latest generation.
The real question is: What fits your use case best — WiFi 6E or WiFi 7?
At Wallys, we’ve worked hands-on with both QCN9024 and QCN6274, two high-performance tri-band wireless modules (2.4G + 5G + 6G). This article will help you understand the differences — and decide which one is right for your design.
📊 QCN9024 vs QCN6274: Feature BreakdownFeatureQCN9024 (WiFi 6E)QCN6274 (WiFi 7)
IEEE Standard802.11ax802.11be
Frequency Bands2.4GHz + 5GHz + 6GHz2.4GHz + 5GHz + 6GHz
Max Bandwidth160 MHz320 MHz (on 6GHz)
MIMO4x4 per band4x4 per band
Modulation1024-QAM4096-QAM
Multi-Link Operation❌ Not supported✅ Supported
Latency OptimizationGoodUltra-low with MLO
Software MaturityVery stable, field-testedGrowing support, Linux-ready
Ideal Use CasesEnterprise routers, FWA, CPEMesh nodes, edge compute, APs
Cost Efficiency⭐⭐⭐⭐⭐⭐⭐⭐ (higher-end WiFi 7)
✅ Why Choose QCN9024
QCN9024 is a WiFi 6E tri-band radio, trusted by developers worldwide for:
  • Mass deployment WiFi routers
  • Enterprise APs & CPEs
  • Smart city edge units
  • Industrial long-range transmission
It’s mature, cost-effective, and pairs well with boards like:
  • DR6018
  • DR5018S
  • DR9574
When you need rock-solid performance and stable software support, QCN9024 delivers.
🚀 Why Choose QCN6274
QCN6274 is a WiFi 7 tri-band module, ready for high-density, high-speed, and ultra-low latency networks.
It unlocks:
  • 320 MHz ultra-wide bandwidth (6GHz)
  • MLO (Multi-Link Operation) for better traffic balancing
  • 4096-QAM modulation
  • Reduced jitter for time-sensitive applications (e.g., video, robotics, mesh)
Perfect match for:
  • DR5332 (IPQ5332)
  • Upcoming IPQ5424 board
  • IPQ9574 high-performance platforms
🧰 Wallys: Beyond Just Hardware
At Wallys, we help you go from board selection to full product deployment:
  • 🔌 Wireless modules: QCN9024, QCN6274, QCN9274
  • ⚙️ Driver support for OpenWrt/QSDK
  • 🧪 RF calibration and long-range performance tuning
  • 🏗️ Enclosure kits, PoE, accessories
  • 🔧 ODM services for full wireless system builds
📩 Need help choosing? Want to compare live performance?
Let’s talk: [url=]sales1@wallystech.com[/url]
🔗 Browse: www.wallystech.com
GMT+8, 2026-10-23 22:32 , Processed in 0.088828 second(s), 7 queries , Gzip On, Redis On.
