查看: 1154|回复: 0
[供应] Performance Comparison: Qualcomm IPQ9574 vs IPQ9570 WiFi 7 Solutions
发表于 2025-9-24 10:39:23 | 显示全部楼层 |阅读模式
As WiFi 7 continues to reshape the wireless networking landscape, Qualcomm’s IPQ9574 and IPQ9570 platforms are two of the most discussed solutions for next-generation routers, access points, and industrial wireless devices. Both chips are built for high-performance applications, yet they target slightly different market needs. In this article, we’ll compare the Qualcomm IPQ9574 vs IPQ9570 to help you decide which platform best fits your project.
1. Overview of Qualcomm IPQ9574
The IPQ9574 is part of Qualcomm’s flagship WiFi 7 portfolio, designed for premium performance in enterprise, carrier-grade, and industrial networking. Key highlights include:
  • Quad-core ARM Cortex-A73 CPU at up to 2.2 GHz
  • Support for tri-band (2.4 GHz, 5 GHz, 6 GHz)
  • Optimized for multi-link operation (MLO) and low-latency applications
  • Large memory support for data-heavy tasks
  • Ideal for WiFi 7 routers, gateways, and high-density APs
The IPQ9574 is often considered the go-to platform for performance-driven WiFi 7 deployments where throughput, stability, and multi-device efficiency are top priorities.
2. Overview of Qualcomm IPQ9570
The IPQ9570 is a slightly lower-tier option compared to the IPQ9574 but still delivers solid WiFi 7 capabilities. It’s designed for projects that need cost-efficiency without compromising WiFi 7 essentials.
Key features include:
  • Quad-core ARM Cortex-A73 CPU, slightly lower clock speed than IPQ9574
  • Support for dual-band or tri-band configurations
  • Strong WiFi 7 feature set, including MLO and 4K QAM
  • Balanced hardware for mid-range enterprise, SMB, and industrial APs
  • Better thermal performance and lower power consumption compared to IPQ9574
The IPQ9570 provides an excellent balance between price and performance, making it attractive for mid-market WiFi 7 deployments.
3. Performance Comparison: IPQ9574 vs IPQ9570FeatureQualcomm IPQ9574Qualcomm IPQ9570
CPUQuad-core Cortex-A73 @ 2.2 GHzQuad-core Cortex-A73 (slightly lower freq)
WiFi BandsTri-band (2.4G/5G/6G)Dual-band/Tri-band options
Target MarketPremium, high-performance WiFi 7Mid-range, cost-optimized WiFi 7
MLO SupportYesYes
Power EfficiencyHigher power drawMore power efficient
Best Use CaseCarrier-grade, high-density enterprise APsSMB, industrial, and mid-tier APs
4. Which One Should You Choose?
  • If your project requires top performance, such as carrier-grade CPE, backbone routers, or enterprise-grade WiFi 7 APs, the IPQ9574 is the right fit.
  • If you prioritize cost-efficiency, power savings, and still need advanced WiFi 7 features, the IPQ9570 is a smart choice for SMB networks, smart cities, and industrial wireless projects.
5. Wallys WiFi 7 Hardware Solutions
At Wallys Communications, we design and manufacture industrial-grade router boards and network cards based on Qualcomm’s latest WiFi 7 platforms, including both IPQ9574 and IPQ9570. Our solutions support custom hardware, software integration, and ODM/OEM services, making them ideal for companies building next-generation WiFi 7 devices.
👉 Learn more about our WiFi 7 products here: [url=]Wallys WiFi 7 Solutions[/url]
📧 Contact us: [url=]sales1@wallystech.com[/url]
GMT+8, 2026-11-19 17:45 , Processed in 0.030534 second(s), 7 queries , Gzip On, Redis On.
