查看: 926|回复: 2
[QCC3系列] compile error - Help
签到总天数:23天
签到总奖励:123金币
发表于 2025-9-29 18:11:26 | 显示全部楼层 |阅读模式
SDK is C:\tools\ADK_Toolkit_1.2.21.13_x64/tools
No console scripts, using workspace tools
BUILDING FOR qcc519x_qcc309x
Using Default Configuration
make.exe: *** No rule to make target 'bt\profile_managers\le_audio\services\gatt_mics_client\gatt_mics_clien', needed by 'output_default/bt/profile_managers/le_audio/services/gatt_mics_client/gatt_mics_client_discovery.o'.  Stop.
C:/tools/ADK_Toolkit_1.2.21.13_x64/tools/bin/make.exe -s -f Makefile -R DEVKIT_ROOT=C:\tools\ADK_Toolkit_1.2.21.13_x64 -j1 -Otarget install BUILD_LEA=TRUE LOGGING_ENABLED=TRUE LOG_LEVEL=3 CHIP_TYPE=qcc519x_qcc309x CHIP_NAME=QCC517x_apps OS_VARIANT=freeRTOS BUILD_TYPE=MAKEFILE PRIVATE_LIBS= PRIVATE_LIBS_SEED=13405 INCPATHS= MAKEFILE_RULES_DIR=C:\codes\adk-src-1-0_qtil_standard_oem_qcc309x.git\adk\tools in C:\codes\adk-src-1-0_qtil_standard_oem_qcc309x.git\adk\src\libs\synergy failed!
18:06:06: The process "C:\tools\ADK_Toolkit_1.2.21.13_x64\ubuild.bat" exited with code 1.
Error while building/deploying project synergy (kit: ADK Toolkit 1.2.21.13 x64 - 1.2.21)
When executing step "Build Project"
18:06:06: FAILED to complete all steps
18:06:06: Elapsed time: 00:16.
1. 代码就是从论坛中download 的 , adk-src-1-0_qtil_standard_oem_qcc309x.git
2. 安装工具, 安装论坛中的方法。
3. 打开 adk-src-1-0_qtil_standard_oem_qcc309x.git\headset\workspace\QCC3095-AA_DEV-BRD-R3-AA 项目编译,就报告了上面的错误。
签到总天数:492天
签到总奖励:9212金币
发表于 2025-9-29 18:33:58 | 显示全部楼层
项目的路径可以改短一些,另外不要有符号,比如改为D:\qcc309x\  类似这种。不要有空格和特殊符号。
回复 支持 1 反对 0
签到总天数:23天
签到总奖励:123金币
 楼主| 发表于 2025-9-30 09:19:51 | 显示全部楼层
jsjj 发表于 2025-9-29 18:33
项目的路径可以改短一些,另外不要有符号,比如改为D:\qcc309x\  类似这种。不要有空格和特殊符号。 ...
好的,谢谢回复
GMT+8, 2026-10-25 17:06 , Processed in 0.022737 second(s), 10 queries , Gzip On, Redis On.
