查看: 674|回复: 0
[供应] IPQ5010 and IPQ6010: Affordable WiFi Platforms for OEM and ODM Projects
发表于 2025-10-23 09:25:57 | 显示全部楼层 |阅读模式
In the fast-evolving world of wireless connectivity, OEM and ODM developers are constantly seeking high-performance yet cost-effective solutions. Qualcomm’s IPQ5010 and IPQ6010 platforms have emerged as powerful options for building next-generation routers, access points, and IoT gateways—without the high price tag associated with enterprise-grade systems.
1. Introduction to IPQ5010 and IPQ6010
Both IPQ5010 and IPQ6010 belong to Qualcomm’s Wi-Fi 6 portfolio, designed to balance performance, efficiency, and affordability.
  • IPQ5010: A dual-core solution optimized for entry- to mid-level Wi-Fi 6 applications.
  • IPQ6010: A quad-core upgrade offering higher throughput and more flexibility for complex networking environments.
These SoCs are part of the same family as IPQ5018 but come at a lower cost—making them ideal for custom OEM/ODM designs that require Wi-Fi 6 performance on a budget.
2. Key Features and SpecificationsFeatureIPQ5010IPQ6010
CPUDual-core ARM Cortex-A53Quad-core ARM Cortex-A53
Wi-Fi StandardIEEE 802.11ax (Wi-Fi 6)IEEE 802.11ax (Wi-Fi 6)
Max Throughput~1.8 Gbps~3.0 Gbps
InterfacesPCIe, USB 3.0, EthernetPCIe, USB 3.0, Ethernet
Target ApplicationsSMB routers, IoT gatewaysEnterprise APs, CPEs, Industrial routers
Both chips feature Qualcomm Networking Pro architecture, delivering improved MU-MIMO performance, OFDMA efficiency, and low-latency connections for multiple concurrent devices.
3. Why They’re Ideal for OEM and ODM Projectsa. Cost-Effective Customization
For OEM/ODM manufacturers, cost is often a critical factor. IPQ5010 and IPQ6010 offer excellent price-to-performance ratios, allowing developers to create Wi-Fi 6-enabled products that are competitive in both function and price.
b. Scalable Design Options
These platforms are scalable across multiple SKUs—from indoor routers and gateways to industrial wireless bridges. Developers can reuse the same board design and upgrade the SoC for different performance tiers.
c. Software Flexibility
Both SoCs support OpenWrt, Qualcomm SDK (QSDK), and Linux-based systems—making it easier to integrate custom firmware, web interfaces, or protocol stacks for industrial and commercial applications.
d. Proven Reliability
Qualcomm’s hardware ecosystem ensures long-term availability and stable driver support—key advantages for long product life cycles typical in industrial and enterprise markets.
4. Application Scenarios
  • Smart City Networks – Reliable backhaul for wireless sensors and surveillance nodes.
  • Industrial IoT Gateways – Connecting PLCs, sensors, and controllers in harsh environments.
  • SMB Wi-Fi Routers – Affordable, high-performance connectivity for small offices.
  • CPE Devices – Customized broadband equipment for ISPs or local network operators.
5. Wallys’ Wi-Fi 6 Solutions Based on IPQ5010/IPQ6010
Wallys Communications offers custom router boards and modules based on the IPQ5010 and IPQ6010 platforms, designed for OEM and ODM customers.
Our boards feature:
  • Optimized power and thermal design for industrial reliability
  • Support for multiple Wi-Fi cards (2.4G + 5G/6G configurations)
  • Fully open SDK and firmware customization
  • Long-term hardware supply and technical support
If you are developing a cost-sensitive Wi-Fi 6 project that still demands reliability and flexibility, Wallys’ IPQ5010/IPQ6010 solutions are the perfect fit.
Conclusion
The Qualcomm IPQ5010 and IPQ6010 platforms offer a sweet spot between affordability and performance. Whether you are designing a compact IoT gateway or a robust industrial router, these Wi-Fi 6 solutions provide the scalability, efficiency, and software freedom that modern OEM/ODM developers need.
👉 Explore Wallys’ IPQ5010/IPQ6010 boards today!
Contact us at [url=]sales1@wallystech.com[/url] to discuss your next project.
Q&A: Common Questions about IPQ5010 and IPQ6010
Q1: What’s the main difference between IPQ5010 and IPQ6010?
A: IPQ5010 is a dual-core Wi-Fi 6 SoC for cost-sensitive or entry-level devices, while IPQ6010 is a quad-core version that offers higher throughput and supports more advanced networking features.
Q2: Are IPQ5010 and IPQ6010 compatible with OpenWrt or QSDK?
A: Yes. Both chipsets are compatible with OpenWrt and Qualcomm’s QSDK, allowing developers to easily customize firmware and integrate third-party software.
Q3: What kinds of projects are these chips suitable for?
A: They are ideal for OEM/ODM Wi-Fi 6 routers, CPE devices, industrial gateways, mesh systems, and IoT hubs requiring high performance at an affordable price.
Q4: Can Wallys provide customization based on these chipsets?
A: Absolutely. Wallys offers custom PCB design, firmware optimization, and ODM/OEM support, helping clients accelerate product development and reduce time to market.
Q5: How can I get a sample or quotation?
A: Simply contact our sales team at [url=]sales1@wallystech.com[/url]and we’ll provide you with detailed specifications, pricing, and evaluation board options.
GMT+8, 2026-11-9 06:22 , Processed in 0.025737 second(s), 8 queries , Gzip On, Redis On.
