查看: 1295|回复: 2
[招聘] Looking for freelancer to develop firmware for Qualcomm QCC5181
 荐  火.. [复制链接]
签到总奖励:5金币
发表于 2026-1-19 18:00:25 | 显示全部楼层 |阅读模式
I have a prototype using standard firmware in a BTM581. This has BT/USB with Bluetooth as the priority. I dont need help with hardware on a fimrware build.
The standard firmware means BT is always on, I would like to be able to specifically switch between BT and USB.
So either the firmware needs to have USB as priority (and then I just switch on/off the USB Vbus to make the module flip between BT and USB) or it needs a way to switch between BT/USB via a GPIO.
The other requirement is that all the standard firmware I have seen is built on the headset firmware so the USB declares as a headset not a speaker. I need the USB to declare as a speaker.
I have a document of the other items (GPIP, PID/VID etc.) which are all not complex as close to what you see in many projects.
Please contact me if you have the knowledge to do above. Note I have a Qualcomm account but I have no expertise in the ADK myself (beyond basic things).
签到总天数:494天
签到总奖励:9219金币
发表于 2026-1-19 18:03:27 | 显示全部楼层
这个问题并不复杂,可以通过PIO切换USB/BT模式。
发表于 2026-4-5 11:42:36 | 显示全部楼层
Your problems aren't complicated. You can use AI to handle them easily.
GMT+8, 2026-11-11 05:00 , Processed in 0.021547 second(s), 10 queries , Gzip On, Redis On.
