查看: 899|回复: 1
[QCC3系列] Firmware for QCC3034 TWS, 500Hz active crossover
发表于 2026-1-21 17:31:38 | 显示全部楼层 |阅读模式
发表于 2026-1-21 17:43:08 | 显示全部楼层
For multichannel audio, it is necessary to use chips that support more than one external DAC, such as the QCC3031 or QCC3021. Otherwise, audio distortions may occur after approximately one hour of music playback. It is also advisable to utilize different Endpoint hardware instance
回复 支持 1 反对 0
GMT+8, 2026-10-23 03:07 , Processed in 0.021012 second(s), 9 queries , Gzip On, Redis On.
