查看: 230|回复: 1
[音频] ES8375 单通道带音频功放CODEC芯片
发表于 2026-7-31 11:21:22 | 显示全部楼层 |阅读模式
ES8375高性能单声道带功放音频CODEC说明书是ES8374的优化产品,性价比更高。System• High performance and low power multi-bit delta-sigma audio ADC and DAC• I2S/PCM master or slave serial data port• 256/384Fs and USB 12/24 MHz audio system clocks• I2C interfaceMono ADC• 24-bit, 8 to 96 kHz sampling frequency• 101 dB signal to noise ratio, -90 dB THD+N• One pair of analog input with differential input option• Low noise pre-amplifier• Support analog and digital microphoneMono Digital Class D• 8 to 96 kHz sampling frequency• 102 dB signal to noise ratio• 1.25W@4Ω• Over current and temperature protection• Pop and click noise suppressionLow Power• 1.8V to 3.3V operation• mW playback and record• Low standby currentAPPLICATIONS• CAT1• Camera• General PurposeORDERING INFORMATIONES8375 -40°C ~ +125°C3x3 QFN-20详细设计指南请联系 李工 18938047300 Q:934434269
连续签到天数:12天
签到总天数:52天
签到总奖励:878金币
发表于 2026-8-3 16:14:59 | 显示全部楼层
感謝樓主分享
GMT+8, 2026-10-22 17:28 , Processed in 0.026761 second(s), 9 queries , Gzip On, Redis On.
