查看: 59432|回复: 23
[CSR8系列] CSR86xx ROM版本一拖二补丁
签到总天数:20天
签到总奖励:100金币
发表于 2014-12-11 16:46:23 | 显示全部楼层 |阅读模式
The audio streamed to a headset in a multipoint configuration will be
// distorted when the link to a second device is lost and the headset tries to
// reconnect to it. This will result in distorted audio being played to the
// speaker.
// This patch stops the headset from attempting to reconnect to a link that has
// been lost if it is receiving A2DP audio on another link. This minimises the
// impact of the lost link on the streamed audio resulting in little or no audio
// distortion.
// The patch uses the ACL closed indication to only indicate a single link-loss event.
签到总天数:174天
签到总奖励:1397金币
发表于 2014-12-11 18:15:45 | 显示全部楼层
签到总天数:1503天
签到总奖励:26914金币
发表于 2014-12-11 22:24:52 | 显示全部楼层
下载看看。。
签到总天数:885天
签到总奖励:8232金币
发表于 2014-12-11 23:14:36 | 显示全部楼层
thank you!!!!!
签到总天数:95天
签到总奖励:2147金币
发表于 2014-12-12 18:20:30 | 显示全部楼层
是8系列的都能用,还是只能8848才可以用?
签到总奖励:6金币
发表于 2014-12-12 18:37:31 | 显示全部楼层
新人mark!!!!!!!!
签到总天数:514天
签到总奖励:3977金币
发表于 2014-12-17 09:27:15 | 显示全部楼层
打了之后连一台手机,放歌两分钟后会出现咔咔断音现象
签到总天数:5天
签到总奖励:48金币
发表于 2014-12-17 09:46:54 | 显示全部楼层
默认不支持一拖二????
签到总天数:836天
签到总奖励:6857金币
发表于 2015-3-21 10:37:04 | 显示全部楼层
8635打了一拖二补丁,没什么效果,刚开机几秒还是会卡
签到总奖励:17金币
发表于 2015-5-4 14:25:48 | 显示全部楼层
加了一拖二功能,自动重连后播放音乐前10秒总是会有杂音,断断续续的
GMT+8, 2026-3-25 17:26 , Processed in 0.114050 second(s), 17 queries , Gzip On, MemCached On.
