查看: 6844|回复: 5
[QCC3系列] QCC3005充电问题
签到总天数:154天
签到总奖励:1539金币
发表于 2020-6-5 09:54:44 | 显示全部楼层 |阅读模式
签到总天数:154天
签到总奖励:1539金币
 楼主| 发表于 2020-6-9 15:16:51 | 显示全部楼层
顶一下
签到总天数:154天
签到总奖励:1539金币
 楼主| 发表于 2020-6-9 15:17:15 | 显示全部楼层
求大佬赐教!!!!!!!!!!!!!
签到总天数:154天
签到总奖励:1539金币
 楼主| 发表于 2020-6-9 16:45:38 | 显示全部楼层
附上外部充电代码
  1. /*
  2. Copyright (c) 2017 Qualcomm Technologies International, Ltd.
  3. */
  4. /*!
  5. @file
  6. @ingroup sink_app
  7. @brief
  8.     Module responsible for interfacing with SMB1352 battery charger
  9. ************************************************************************/
  10. #ifndef SINK_EXT_CHARGER_H
  11. #define SINK_EXT_CHARGER_H
  12. #define EXT_CHG_NUM_REGS (21)
  13. #define EXT_CHG_REG_STS_FLOAT_VOLTAGE (0x38)
  14. #define EXT_CHG_MASK_STS_FLOAT_VOLTAGE (0x3F)
  15. #define EXT_CHG_FLOAT_BASE_MILLIVOLTS (3500)
  16. #define EXT_CHG_FLOAT_STEP_MILLIVOLTS (20)
  17. #ifdef ENABLE_EXT_CHARGER
  18. void sinkExtChargerInit(void);
  19. uint16 sinkExtChargerReadFloatVoltage(void);
  20. #else /* not def ENABLE_EXT_CHARGER */
  21. #define sinkExtChargerInit() ((void) 0)
  22. #define sinkExtChargerReadFloatVoltage() ((uint16) 0)
  23. #endif /* def ENABLE_EXT_CHARGER */
  24. #endif /* def SINK_EXT_CHARGER_H */
复制代码
  1. /*
  3. */
  4. /*!
  5. @file
  7. @brief
  10. #include <i2c.h>
  11. #include "sink_configmanager.h"
  12. #include "sink_debug.h"
  13. #ifdef ENABLE_EXT_CHARGER
  14. #include "sink_ext_charger.h"
  15. #include "sink_ext_charger_config_def.h"
  16. #ifdef DEBUG_EXT_CHG
  17. #define EXT_CHG_DEBUG(x) DEBUG(x)
  18. #else
  19. #define EXT_CHG_DEBUG(x)
  20. #endif
  21. #define EXT_CHG_REG_CMD_I2C (0x30)
  22. #define EXT_CHG_CMD_ENABLE_VOLATILE_WRITES (0x40)
  23. static uint8 ext_chg_i2c_address;
  24. /****************************************************************************
  25. NAME
  26.     reg_read
  27. DESCRIPTION
  28.     Read from a register on the external charger
  29. RETURNS
  30.     TRUE iff the read was successful
  31. */
  32. static bool reg_read(uint8 reg, uint8 *data)
  33. {
  34.     uint16 ack = I2cTransfer(ext_chg_i2c_address, &#174;, 1, data, 1);
  35.
  36.     /* Expect addr + reg + addr + data (4 bytes) acknowledged */
  37.     if (ack == 4)
  38.     {
  39.         return TRUE;
  40.     }
  41.
  42.     EXT_CHG_DEBUG(("ext_chg: reg read failed; addr=0x%02X len=%u\n", ext_chg_i2c_address, ack));
  43.     return FALSE;
  44. }
  45. /****************************************************************************
  46. NAME
  47.     reg_write
  48. DESCRIPTION
  49.     Write to a register on the external charger
  50. RETURNS
  51.     TRUE iff the write was successful
  52. */
  53. static bool reg_write(uint8 reg, uint8 data)
  54. {
  55.     uint8 packet[2];
  56.     uint16 ack;
  57.
  58.     packet[0] = reg;
  59.     packet[1] = data;
  60.     ack = I2cTransfer(ext_chg_i2c_address, packet, 2, NULL, 0);
  61.
  62.     /*  Expect addr + reg + data (3 bytes) acknowledged */
  63.     if (ack == 3)
  64.     {
  65.         return TRUE;
  66.     }
  67.
  68.     EXT_CHG_DEBUG(("ext_chg: reg write failed; addr=0x%02X len=%u\n", ext_chg_i2c_address, ack));
  69.     return FALSE;
  70. }
  71. /****************************************************************************
  72. NAME
  73.     reg_write_enable
  74. DESCRIPTION
  75.     Enable / disable writes to the external charger configuration registers,
  76.     panic on failure
  77. RETURNS
  78.     void
  79. */
  80. static void reg_write_enable(bool enable)
  81. {
  82.     PanicFalse(reg_write(EXT_CHG_REG_CMD_I2C, enable ? EXT_CHG_CMD_ENABLE_VOLATILE_WRITES : 0));
  83. }
  84. /****************************************************************************
  85. NAME
  86.     sinkExtChargerInit
  87. DESCRIPTION
  88.     Initialise the external charger by writing the stored configuration,
  89.     panic on failure
  90. RETURNS
  91.     void
  92. */
  93. void sinkExtChargerInit(void)
  94. {
  95.     ext_charger_config_def_t *config;
  96.     uint16 size;
  97.
  98.     size = configManagerGetReadOnlyConfig(EXT_CHARGER_CONFIG_BLK_ID, (const void **) &config);
  99.     EXT_CHG_DEBUG(("ext_chg: size=%u\n", size));
  100.     if (size)
  101.     {
  102.         uint16 reg;
  103.
  104.         ext_chg_i2c_address = config->ext_charger_i2c;
  105.
  106.         reg_write_enable(TRUE);
  107.         for (reg = 0; reg < EXT_CHG_NUM_REGS; ++reg)
  108.         {
  109.             PanicFalse(reg_write(reg, config->ext_charger_data[reg]));
  110.         }
  111.     }
  112.
  113.     configManagerReleaseConfig(EXT_CHARGER_CONFIG_BLK_ID);
  114.     reg_write_enable(FALSE);
  115.
  116.     EXT_CHG_DEBUG(("float %u mV\n", sinkExtChargerReadFloatVoltage()));
  117. }
  118. /****************************************************************************
  119. NAME
  120.     sinkExtChargerReadFloatVoltage
  121. DESCRIPTION
  122.     Read the float voltage from the external charger
  123. RETURNS
  124.     Float voltage in millivolts
  125. */
  126. uint16 sinkExtChargerReadFloatVoltage(void)
  127. {
  128.     uint8 data;
  129.
  130.     PanicFalse(reg_read(EXT_CHG_REG_STS_FLOAT_VOLTAGE, &data));
  131.     return EXT_CHG_FLOAT_BASE_MILLIVOLTS + EXT_CHG_FLOAT_STEP_MILLIVOLTS * (data & EXT_CHG_MASK_STS_FLOAT_VOLTAGE);
  132. }
  133. #endif /* def ENABLE_EXT_CHARGER */
复制代码
签到总天数:51天
签到总奖励:359金币
发表于 2020-12-22 15:04:59 | 显示全部楼层
楼主,可以交流一下充电问题吗
签到总天数:154天
签到总奖励:1539金币
 楼主| 发表于 2020-12-30 11:13:11 | 显示全部楼层
一起学高通芯片 发表于 2020-12-22 15:04
楼主,可以交流一下充电问题吗
我也是新手
GMT+8, 2024-4-26 21:26 , Processed in 0.212348 second(s), 17 queries , Gzip On, MemCached On.
