查看: 81388|回复: 40
[BC5系列] BC5 串口收发问题
发表于 2013-11-3 20:14:13 | 显示全部楼层 |阅读模式
  1. typedef struct{
  2.     TaskData task;
  3. }bt_uart_t;
  4. bt_uart_t bt_uart;
  5. extern BT_INFO *pBtInfo;
  6. static void UartRecv(BT_INFO *pBtInfo)
  7. {
  8.     Source src;
  9.     uint8 *s = NULL;
  10.     uint8 size = 0;
  11.
  12.     src = StreamUartSource();  /* get the uart source header */
  13.     s = (uint8*)SourceMap(src);  /* get the uart source memory */
  14.     size = SourceSize(src);
  15.     memcpy(&pBtInfo->uart.buf[0],s,size);
  16.     SourceDrop(src,size);    /*Discards the indicated number of bytes from the front of the source*/
  17. }
  18. static void UartHandler(Task task, MessageId id, Message message)
  19. {
  20.      DBGD(("\nUart recv id:----> %d",id));
  21.     switch (id)
  22.     {
  23.         case MESSAGE_MORE_DATA:
  24.             UartRecv(pBtInfo);
  25.             DBGD(("Uart recv data:\n"));
  26.             break;
  27.         default:
  28.             break;
  29.      }
  30. }
  31. void InitUart(BT_INFO *pBtInfo)
  32. {
  33.     bt_uart.task.handler = UartHandler;
  34.     StreamUartConfigure(VM_UART_RATE_115K2,VM_UART_STOP_ONE,VM_UART_PARITY_NONE);
  35.     /*MessageSinkTask(StreamUartSink(), &bt_uart.task);*/
  36.     MessageSinkTask(StreamSinkFromSource(StreamUartSource()),&bt_uart.task);
  37. }
  38. void UartSend(BT_INFO *pBtInfo,uint8 *buf, uint16 len)
  39. {
  40.     Sink sink;
  41.
  42.     if (buf == NULL || len == 0)
  43.     {
  44.         DBGD(("Uart Send buf is NULL or len is zero\n"));
  45.     }
  46.     /*sink = StreamUartSink();*/
  47.     sink = StreamSinkFromSource(StreamUartSource());
  48.     if(sink && SinkClaim(sink, sizeof(uint8)*len) != 0xFFFF)
  49.     {
  50.          memcpy(SinkMap(sink), buf, sizeof(uint8)*len);
  51.         /*SinkFlush*/
  52.         PanicZero(SinkFlush(sink, sizeof(uint8)*len));
  53.     }
  54.     else
  55.     {
  56.         DBGD(("Can not send uart\n"));
  57.      }
  58. }
复制代码
 楼主| 发表于 2013-11-3 20:15:09 | 显示全部楼层
串口收发都不成功,请大神帮忙看一下,谢谢
签到总天数:2416天
签到总奖励:64939金币
发表于 2013-11-3 23:12:17 | 显示全部楼层
楼主和我一样的问题呀,楼主用的ADK多少版本的,一起讨论下
 楼主| 发表于 2013-11-4 09:49:04 | 显示全部楼层
我用的是ADK2.0
签到总天数:22天
签到总奖励:126金币
发表于 2013-11-4 10:13:47 | 显示全部楼层
这个不会搞啊!求教!
 楼主| 发表于 2013-11-4 10:42:58 | 显示全部楼层
听说初始化那要改成这样,我还没试
    MessageSinkTask(StreamUartSink(),&bt_uart.task);
    StreamConfigure(VM_STREAM_UART_CONFIG,VM_STREAM_UART_LATENCY);
回复 支持 0 反对 1
签到总天数:2416天
签到总奖励:64939金币
发表于 2013-11-6 21:41:21 | 显示全部楼层
transport设为Raw
签到总天数:2416天
签到总奖励:64939金币
发表于 2013-11-6 21:42:02 | 显示全部楼层
楼主的uart通了吗?最近都在搞cc2540
签到总天数:7天
签到总奖励:26金币
发表于 2013-11-7 09:08:10 | 显示全部楼层
参观学习。。
发表于 2013-11-7 09:18:01 | 显示全部楼层
学习.学习.....
GMT+8, 2026-5-16 06:44 , Processed in 0.157058 second(s), 19 queries , Gzip On, MemCached On.
