查看: 2416|回复: 0
[其他] Wallys|QSDK moudle/QCA9880 Mini PCIe 2.4G/5G MTK MT7915 IPQ4019/IPQ4029
签到总奖励:18金币
发表于 2022-10-14 11:01:31 | 显示全部楼层 |阅读模式
wallys, a technology company that develops, designs and manufactures wireless communications products, has 90% of the world’s customers and is a supplier to facebook.
From 802.11n to 802.11ax, it has been moving forward, and has been trusted and supported by more and more customers.
wallys also supports custom development of software and hardware, including customized products.
With a history of 10 years, Wallys has been very mature in the design and development of hardware and software in wireless communication. It also supports customization and software development, and has won the trust of 90% of customers around the world and reached a long-term cooperative relationship. It is also a supplier of facebook.
Wallys mainly uses Qualcomm and MTK chips. The main products include router, moudle, industrial access AP and antenna, which are of industrial grade, and the quality and performance fully meet the requirements of users.
The following are the best-selling products of Wallys. Let’s take a look at them together. You can contact us at any time if you are in need, or enter our company’s official website to check more product information.
Skype/EMAIL:sales@wallystech.com
DR900VX( QCA9880 chipset
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
FCC,CE and IC Certification
DR7915( MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G  MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check  (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
CardsareindividuallycalibratedforQualityAssurance
The above two MINI PCIE Moudle can be used on the DR40x9(Quaclomm IPQ4019/IPQ4029) industrial wifi5 router. Let’s take a look at the introduction of this board
DR40X9
Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
Our Firmware supports all the modules of Quectel
GMT+8, 2025-9-16 02:56 , Processed in 0.133872 second(s), 15 queries , Gzip On, MemCached On.
