查看: 2631|回复: 0
[供应] Wallys|QSDK 5G router/AR9344 802.11a/802.11n support QCA9880/QCA9882/Minipcie...
签到总奖励:18金币
发表于 2022-10-24 14:30:19 | 显示全部楼层 |阅读模式
Wallys|QSDK 5G router/AR9344 802.11a/802.11n support QCA9880/QCA9882/Minipcie card   FCC/CE/IC
wallys, a technology company that develops, designs and manufactures wireless communications products, has 90% of the world's customers and is a supplier to facebook.
From 802.11n to 802.11ax, it has been MOVing forward, and has been trusted and supported by more and more customers.
wallys also supports custom development of software and hardware, including customized products.
Skype/EMAIL:sales@wallystech.com
Web:https://www.wallystech.com/
https://www.wallystech.com/Routerboard/DR344-Qualcomm-AR9344-support-MU-MIMO-2T2R-5G-2-GETH-port-support-Minipcie-card.html
DR344
AR9344 802.11a/802.11n 5G
AR9344 FCC/CE/IC
AR9344 is the industry's top WLAN chip manufacturer Atheros's new generation WLAN SoC, the core is MIPS 74Kc, the main frequency is up to 533MHz, with a high degree of integration. Suitable for developing wireless router, wireless AP, wireless bridge, etc.
The AR9344 integrates a PCI-e Root Complex and a PCI-e Endpoint interface, a 5-port 100-Megabit Ethernet switch, a MII/RMII/RGMII interface, a USB2.0 MAC/PHY, and supports DDR1/DDR2 SDRAM. Supports SPI Flash and NAND Flash. The I2S/SPDIF audio output interface of AR9344 can be connected to an audio codec chip for audio related applications.
The AR9344 is internally integrated with high performance MAC/ baseband/RF and supports 2.4GHz/5GHz 2×2 MIMO, providing up to 300Mbps wireless bandwidth.
AR9344 features:
74kc MIPS processor with 64KB I-Cache and 32KB D-Cache operating up to 560mhz, external 16-bit or 32-bit DDR1, DDR2 operating up to 225MHz (450m transmission/SEC),NAND and SPI and Flash memory support; SLIC for VOIP/PCM, 10/100 Ethernet switch with 5 IEEE 802.3 Ethernet LAN ports,MII/RGMII interface; 802.3az energy-efficient Ethernet is compatible with hardhard-based Ethernet interface NAT&ACL accelerator, supports PCIExpress 1.1 root complex and endpoint interface, a built-in MAC/PHY USB2.0 controller, supports host or device mode, and boot from external CPU via PCIE, USB, xMII. No external flash memory,I2S/SPDIF-OUT audio interface; Optional external LNA/PA, a low speed UART(115 Kbps), a high speed UART(3 Mbps) and multiple GPIO pins for general purpose I/O, fully integrated RF front-end, including PAS and LNAs; Advanced dynamic power management,25MHz or 40MHz reference clock input; 1.2V switching regulator
Featuring with industrial-grade Atheros/ AR9344(560 MHz)chipset,DR344
Integrated with 1 x 5G high power (up to 30dBm aggregate ) radio card
Supports 1 x 10/100Mbps Fast Ethernet Port and 1 x 10/100/1000Mbps Gigabit Ethernet Port
Support WiFi application(Optional)
Support 2 x 5G MMCX connectors
Support 5M/10M/20M/40M Bandwidth
Support 1 x USB2.0(Optional)
Support operating frequency from 2.312 GHz to 2.502 GHz and 4.92GHz to 6.085GHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Hardware Information
CPUAtheros/AR9344-AC2A 560 MHz processor frequency
System Memory64MB(max 128MB DDR2 optional)
NOR Flash8MB (max 16MB optional)
Switch ICAtheros/AR8035-AL1A-R 1 GIGA port PHY/RGMII switch
Power ICTI/TPS54531 24V to 5V 5A regulator
AME/AME5291 5V to 3.3V 2A regulator
Power consumption2.04W(Board Only)
6.6W(Board + 2.4G card)
7.1W(Board + 5G card)
1000M LAN port POE definePin 4/5 and pin 7/8 connect to the anode or cathode respectively 24V input
Antenna Connector2 x 5G MMCX connectors(U3&U5)
Power Connector1 x DC JACK(J2)D(center)=2.1mm Max 24V DC input /1 x 2 pin header pitch=3.96mm(J32)
LAN Connector1 x 100M LAN(J4) port / 1 x 1000M LAN port(J3)
ROHS ComplianceYES
HumidityOperating: 5% to 95% (non-condensing); Storage: Max.90% (non-condensing)
Temperature RangeOperating: -20ºC to 70ºC; Storage: -40ºC to 90ºC
Reset ButtonRT push button(SW6)
Dimension105mm x 105mm x 15.1mm
The DR344 supports Wallys mini pcie cards, such as Qualcomm QCA9880/QCA9882 chipset.
The following specific to introduce to you about several mini pcie cards.
DR900VXQCA9880 802.11ac Dual bandQCA9880 3x3 2.4G/5G FCC/CE/IC
Qualcomm-Atheros QCA9880 chipset
2.4GHz max 26dBm & 5GHz max 25dBm output power
IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
3x3 MIMO Technology, up to 1.3Gbps
Mini PCI Express edge connector
Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
FCC,CE and IC Certification
DR600VX
QCA9880 2x2 2.4G/5G FCC/CE
2.4GHz max 24dBm & 5GHz max 23dBm output power
IEEE 802.11accompliant & backward compatible with 802.11a/b/g/n
2x2 MIMO Technology, up to 867Mbps
Support the Frequency 4920MHz~4980MHz
(LDPC) Codes, Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Commercial processes and communications are all managed utilising wireless technologies, and the number of users, devices and apps are only going to increase.  Therefore, it is essential to have a rOBUst, secure and high performing WiFi solution that is future-proofed, mobile, and scalable.  Not only is business WiFi vital for your workforce and organisation, it is now imperative for visitors to be able to access a secure guest wireless network.
Wallys has been specializing in product design & manufacturing and delivering superior OEM/ODM services in wireless communications. Dedicated to innovative designs for wireless modules. Customization is also supported, We have 90% of the world market, We're a supplier to Facebook.
GMT+8, 2026-10-24 15:54 , Processed in 0.065371 second(s), 10 queries , Gzip On, Redis On.
