查看: 1727|回复: 0
[供应] IPQ9574 work with QCN9274 cpu DR9574 router + DR9274-6G the throughput test
签到总奖励:18金币
发表于 2024-2-28 14:05:52 | 显示全部楼层 |阅读模式
Generally speaking, the higher the throughput of a WiFi router, the better its performance will usually be. Higher throughput means that the router can provide faster data transfer rates, allowing more devices to connect simultaneously and transfer data at high speeds.
High-throughput routers can provide more stable and faster wireless connections and are suitable for applications with high bandwidth requirements, such as high-definition video streaming, online gaming, and large file downloads. If you have multiple devices connected to your WiFi network at the same time and need to transfer a lot of data, a router with high throughput will be better able to meet your needs.
as you see,throughput up to 8.9G , If the environment is better, it can reach 9G+, close to 10G.
Wallys had tested WiFi7 router DR9574 and WiFi7 moudle DR9274-6G throughput。
DR9574 routerboard
802.11be [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]IPQ9574 4x4 2.4G 2x10G +4x1G Ethernet Port
Support WIFI7 card QCN9274-QCN6274
DBDC 2x2 2.4G& 2x2 5G
DBDC 2x2 5G& 2x2 6G
single band 4x4 5G
single band 4x4 6G
WLAN Host InterfaceCI Express 3.0 Interface
Frequency Range:2.4GHz: 2.412~2.472GHz
DR9274-6G
DR9274-6G based on [color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]QCN9274 Chipset is an enterprise wireless module integrated with 4x4 MU-MIMO single Band Wireless Module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RFenvironment in factories, warehouses establishment
4x4 6G MU-MIMO WiFi Module
WIFI7 M.2 card QCN9274
■ Qualcomm Atheros QCN9274 for Industrial Grade;
■ Maxim Tx power 22dBm per chain;
■ 4x4  6G MU-MIMO, up to 11530Mbps physical data rate;
■ Support up to 4096-QAM;
■ M.2 connector;
■ PCI Express 3 .0 Interface
DR9274-6G
Email:[color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]sales@wallystech.com
WEB:[color=var(--color-action)][backcolor=var(--artdeco-reset-link-background-color-transparent)]https://www.wallystech.com/
GMT+8, 2026-10-24 05:33 , Processed in 0.020081 second(s), 8 queries , Gzip On, Redis On.
