查看: 1486|回复: 0
[供应] Wallys|QSDK DR-AP40X9(Outdoor) IPQ6010 IPQ4019 IPQ4029 802.11ax/ac Outdoor A...
签到总奖励:18金币
发表于 2022-10-18 12:01:09 | 显示全部楼层 |阅读模式
Wallys|QSDK industrial IPQ6010 IPQ4019 IPQ4029 802.11ax/ac support QCA9880/QCA9882 moudles Outdoor AP Plastic
wallys, a technology company that develops, designs and manufactures wireless communications products, has 90% of the world’s customers and is a supplier to facebook.
From 802.11n to 802.11ax, it has been moving forward, and has been trusted and supported by more and more customers.
wallys also supports custom development of software and hardware, including customized products.
With a history of 10 years, Wallys has been very mature in the design and development of hardware and software in wireless communication. It also supports customization and software development, and has won the trust of 90% of customers around the world and reached a long-term cooperative relationship. It is also a supplier of facebook.
Wallys mainly uses Qualcomm and MTK chips. The main products include router, moudle, industrial access AP and antenna, which are of industrial grade, and the quality and performance fully meet the requirements of users.
The following are the best-selling products of Wallys. Let’s take a look at them together. You can contact us at any time if you are in need, or enter our company’s official website to check more product information.
Skype/EMAIL:sales@wallystech.com
DR-AP40X9(Outdoor)
Support IPQ6018 IPQ4019 IPQ4029 802.11ax 802.11ac
Outdoor AP Plastic Support DR4029/DR6018-S 275x140x48mm
Description
DR-AP4029(Outdoor) is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;1 x Onmi Antenna; 1 x POE Adapter(24V^1A~48V^0.6A);1 x Enclosure.
Planar?Antenna?
■? 2 x 5G Antenna
■? 5G: 16dbi
DRA25?Antenna
ElectricalProperties :?
Frequency Range:2.4~2.5&5.15~5.85GHz?
Impedance:50??
VSWR:2.0 Max (≤2.0)?
Gain(peak):6±0.5dBi
Polarization:Linear; Vertical
Physical Properties :
Cable:RG-141 Cable?
Connector:N-type PLUG?
Antenna CAP:ABS?
OperatingTemp:-40℃~+65℃?
Storage Temp:-40℃~+75℃?
CableTemp:<+250℃
Enclosure
■? Dimension: 275x140x48mm
■? UV Protected and Durable ABS Radome
■? IP67?Waterproof Level
■? Support Wallys??DR4029?018-S
DR40x9
IPQ4019 IPQ4029 ,802.11AC 2x2 2.4G&5G
2x2 2.4Ghz&5G Support HTTPS Support all the modules of Quectel
Featuring with industrial-grade?IPQ4019/IPQ4029?chipset?
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module?
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz?
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX?
Our Firmware supports all the modules of Quectel
DR6018-S
QCN9074 WiFi Card IPQ6010,IPQ6018 802.11ax
Support OpenWRT 2x2 2.4G&5G??
DR6018-S V02?IPQ6010/IPQ6018/IPQ6000
DR900VX
QCA9880 802.11ac Dual band
QCA9880 3x3 2.4G/5G FCC/CE/IC?
DRA25
DRa25 2.4~2.5&5.15~5.85GHz RG-141 Cable N-type PLUG
2.4G&5G 6±0.5dBi 50? 2.0 Max (≤2.0)
GMT+8, 2026-10-24 02:11 , Processed in 0.020565 second(s), 8 queries , Gzip On, Redis On.
