查看: 1593|回复: 0
[CVC相关] Wallys/industrial wifi6 router/Qualcomm /IPQ8072A IPQ8072 4T4R/OpenWRT 802.11...
签到总天数:8天
签到总奖励:36金币
发表于 2022-11-3 16:47:57 | 显示全部楼层 |阅读模式
wifi6 Qualcomm /IPQ8072A IPQ8072 4T4R/OpenWRT 802.11AX/10GE port/10G SFP.
1. Define Edit Broadcast
The wireless communication realized in the movement is also known as mobile communication, and people call the two together as wireless mobile communication.
2. Editing and broadcasting of technical principles
Wireless communication is a communication method that uses the characteristics that electromagnetic wave signals can propagate in free space to exchange information. In the field of information communication in recent years, wireless communication technology is the fastest-growing and most widely used. The wireless communication realized in the movement is also known as mobile communication, and people call the two together as wireless mobile communication.
The development of modern telecommunications over 150 years from the very beginning of the telegraph is the result of the hard work of thousands of scientists, engineers and researchers from all walks of life. Only a few of them who were solely responsible for the invention became famous, and most of the inventions that culminated were the work of many individuals. Here are some of the historical figures who played an important role in the development of radio communications.
Q3:is Qualcomm QSDK a onetime license fee or some other subscription / royalty fees ?     will the HW support standard OpenWRT without using QSDK ?   Look like your SW images is based on OpenWRT and OpenWRT is completely free and open source.
qsdk need license fee
The firmware onboard is from qsdk. We also have github where the opensource support our boards
BY:Wallys Communications (Suzhou ) Co., LTD
1. DR8072V01
https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualcomm-IPQ8072A-4T4R-support-OpenWRT-802.11AX-supporting-10GE-port-10G-SFP.html
https://www.youtube.com/watch?v=-WxNI6WXFDI&t=22s
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND FlashNAND Flash can be up to 1GB as optional
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK09
System Memory
1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range
2.412~2.472GHz,
5.150~5.825GHz
M.2 Slot
1x M.2 Slot with PCIe 3.0
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
Flash
NOR Flash: 8 MB
NAND Flash: 256MB(1GB optional)
Wireless
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain
8x U.FL Connectors
Reset Buttons
1x S/W Reset Button
DC Jack Input
1x DC Jack Connector: 12V
Interface
4x 1Gbps Ethernet Port,
1x 10Gbps Ethernet Port
1x 10Gbps SFP
2x USB 3.0 Port
1x JTAG 20 Pin Connector
1x Serial Port 4 Pin Connector
LED
2x RGB LED Indicators
Power Consumption
TBD
industrial wifi router
industrial wifi5 router
industrial 5g router
industrial 4g router
industrial 2.4g router
industrial wifi moudle
industrial wifi5 moudle
industrial wifi6 moudle
industrial 5g moudle
industrial 2.4g moudle
industrial 6g moudle
industrial mini pcie card
industrial M.2 card
GMT+8, 2025-5-31 08:00 , Processed in 0.265796 second(s), 15 queries , Gzip On, MemCached On.
