查看: 8847|回复: 3
[QCC3系列] GAIA App BAND cofiguration not saved .
发表于 2022-12-9 14:00:40 | 显示全部楼层 |阅读模式
Hi all,
As i am using QCC3024. Everything is working fine .But from my GAIA app wherver i change in band GAIN . Its working perfectly till the GAIA app open. once the device is connected with other one that GAIN settings is no more working. Its just reset with Ideal one.
I tried it a lot but cant be able fix it.
Pleasee me when i change in gain using GAIA how to set in the QCC3024. IS that any setting required or any steps requiereed to set the chage done fro GAIA app.
签到总天数:120天
签到总奖励:1272金币
发表于 2022-12-15 17:45:44 | 显示全部楼层
gaia更改的数据不会存入flash中  建议使用qact进行调试
 楼主| 发表于 2022-12-20 15:47:31 | 显示全部楼层
Thanks senior,
As you suggest to debug it. Kindly share the details for how i can do it. Currently i am using QCC3024 for this.
we are changing a few EQ band just for testing purpose but as its not going to stores it. Because i need the solution like whenever  i will change the EQ bands change it will always upgrade in the device and perform accordingly
签到总天数:492天
签到总奖励:9212金币
发表于 2022-12-20 16:29:22 | 显示全部楼层
GMT+8, 2026-10-22 18:18 , Processed in 0.028180 second(s), 13 queries , Gzip On, Redis On.
