查看: 10476|回复: 3
[QCC3系列] GAIA EQ Retention in QCC30xx
发表于 2023-5-19 20:27:41 | 显示全部楼层 |阅读模式
I'm trying to set custom EQ using GAIA Demo Application in my device running on QCC3024 but I'm not able to retain the EQ parameters once connection with GAIA has been disconnected. Is there any way to retain these EQ parameters in device itself?  or I have to change the SoC to another series?
Another thing if this feature is supported in QCC3040/QCC3034 or not!? If not, recommend some SoC that supports this feature.
签到总天数:495天
签到总奖励:12160金币
发表于 2023-5-20 13:36:00 | 显示全部楼层
是的,存在bug
签到总天数:181天
签到总奖励:3035金币
发表于 2023-5-22 10:40:30 | 显示全部楼层
The EQ data were kept in the FLASH with QCC3040, I'm sure.
 楼主| 发表于 2023-5-22 14:20:35 | 显示全部楼层
Thank you!
GMT+8, 2026-11-3 06:00 , Processed in 0.023146 second(s), 13 queries , Gzip On, Redis On.
