查看: 14910|回复: 2
[供应] Wallys/Wi-Fi 6E/2.4~2.5&5.15~7.15GHz
签到总天数:8天
签到总奖励:36金币
发表于 2023-1-10 16:07:17 | 显示全部楼层 |阅读模式
WiFi 6E,2.4~2.5&5.15~7.15GHz ,dipole antenna
Wi-Fi 6E,2.4~2.5&5.15~7.15GHz
DRA24126ESBE
Wallys Communications (Suzhou ) Co., LTD(http://www.wallystech.com) is a professional supplier of wireless communication products and has a complete industrial chain in China. Our biggest advantage is our independent research and development ability, which can support you in the later period.
IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ8072/IPQ8074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344/AR9531
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:​sales3@wallystech.com
wifi6 router/network card
wifi 6E
WiFi 6
802.11ax/802.11ac
wireless solutions
Dipole/ panel //Dual Polarization Enclosure /Smart /omni /Antenna
Wireless Access Point/Point to Point /
  • Feature
*External type dipole antenna
  • 2.4~2.5&5.15~7.15GHz of frequency
  • Plastic rod of Black
  • RoHS compliance
  • Application
  • Wi-Fi 6E Wireless Communication
  • WLAN device, WLAN Router, e.g., AP,PIC Wireless Card
  • Description
Suzhou Wallys Communication Co., Ltd, this miniature antenna is designed for Wi-Fi 6E applications
and can be easily built-in portable devices for SMA Plug. It has excellent stability and sensitivity to
consistently provide high signal reception efficiency
  • General Data
Symbol
Parameter
Product Name
Wi-Fi 6E Dipole Antenna
Part No.
DRA24126ESBE
Frequency
V.S.W.R
2.4-1.92max 5.85-2.1max
Gain(dBi)
2.45GHz@3.0dBi
5.85GHz@4.0dBi
Polarization
Linear,Vertical
Storage Temp
-10℃~+70℃
Operating Temperature
-10℃~+60℃
Impedance with Matching
50 Ω
Weight
6.5 g
Antenna Type
SMA Plug
Dimension
L108.4X φ 11.0 (mm)
签到总天数:221天
签到总奖励:2792金币
发表于 2023-1-11 17:50:52 | 显示全部楼层
好产品
签到总天数:8天
签到总奖励:36金币
 楼主| 发表于 2023-1-12 10:08:16 | 显示全部楼层
GMT+8, 2026-11-3 10:23 , Processed in 0.020108 second(s), 10 queries , Gzip On, Redis On.
