查看: 2396|回复: 0
[嵌入式] Wallys//IPQ8072/IPQ8074/IPQ8072A/IPQ8074A/High-capacity 802.11ax SoC for Rout...
签到总天数:8天
签到总奖励:36金币
发表于 2022-10-9 10:46:17 | 显示全部楼层 |阅读模式
IPQ8074A 4x4 2.4G 8x8 5G 802.11ax
The IPQ8074 is Qualcomm’s first 802.11ax network solution, designed to meet the growing demands of increasingly crowded and dense Wi-Fi environments. It offers the optimal 11ax configuration to bring unprecedented capacity and coverage to Wi-Fi networks, and supports several unique features to ensure the best possible Wi-Fi performance for all types of applications.
Qualcomm IPQ8074 802.11ax WiFi 6 SoC was first unveiled in 2017 and designed for high-end routers, gateways, and access points supporting up 12×12 MIMO configuration (8×8 5GHz + 4×4 2.4 GHz) using Dual-Band Dual Concurrency (DBDC).
I was just informed about a Qualcomm IPQ8074 embedded board going under the names DR8074A or HK01 depending on the company promoting it
1. DR8074A(HK01)
https://www.wallystech.com/Routerboard/DR8074A-HK01-wifi6-Qualcomm-IPQ8074A-4T4R-2-4GHz-and-8T8R-5GHz-support-OpenWRT-802.11AX-MU-MIMO-OFDMA.html
Features
■ Qualcomm Atheros IPQ8074A AR Quad Core CPU
■ On-board 5GHz radio, up to 4804Mbps physical data rate 32MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 11ax TX Beamforming
■ Support 11ac/ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz + 4x4/5GHz) + 4x4/2.4GHz
Absolute Maximum Rating
Parameter
Rating
Unit
Operating Temperature Range
-20 to +70
ºC
Storage Temperature Range
-40 to +90
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8074A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK01
System Memory
1GB (2x 512MB) DDR3L 32-bit interface
Frequency Range
2.412GHz to 2.472GHz, 5.150GHz to 5.825GHz
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
NGFF Slot for 5G Module
M.2 (NGFF) “B Key” Socket with PCIe 3.0 interface
Optional Onboard Modules
Supports 1x BT module,1x ZigBee module,1x Touch pad connector,1x Audio header,1x LCD display header
Flash
NOR Flash: 32MB NAND Flash: 256MB
eMMC: 8GB
Wireless
On-board 4x4 2.4GHz MU-MIMO 802.11b/g/n/ax, max TBDdBm per chain
On-board 2x(4x4) or 8x8 5GHz MU-MIMO 802.11a/802.11n/802.11ac/802.11ax, max TBDdBm per chain
12x U.FL connectors
Reset Buttons
2x Hardware reset button, 1x WPS reset button
DC Jack Input
1x DC Jack Connector: 12V, 5A
Interface
5x Gigabit Ethernet (1GbE) LAN/WAN RJ45 Port (Auto MDI-X)
1x 10Gigabit Ethernet (10GbE) LAN/WAN RJ45 Port (Auto MDI-X) 1x SFP+ Port
2x USB 3.0 Port
1x Serial Port 12 Pin Connector 1x JTAG 20 Pin Connector
1x micro SD Card Socket
1x M.2 Slot
LED
13x LED indicators, 2 additional LED on Ethernet port
Power Consumption
TBD
The following are our main chips and website information, if you are interested in our products, you can also directly contact our mailbox, we will provide you with the best service!
FYI, Wallys are able to provide customizable solutions based on your your Spec requirements for applications, feel free to let me know if any question
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/QCN6024/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344 /AX200NGW/ AP9342
With over 15 years of experience in wireless industry and penetrating market olfaction, Wallys has designed and manufactured many high quality and cost-effective routerboards and wireless network cards.
In the complex market, Wallys products stand out and are affirmed by partners. From 802.11 a - ax, Wallys always keeps up with the most cutting-edge wireless technology, aimed to help customers take the preemptive opportunities to occupy the market and lead a win -win cooperation.
BY:Wallys Communications (Suzhou ) Co., LTD
EMAIL:​sales3@wallystech.com
GMT+8, 2026-11-3 11:28 , Processed in 0.029935 second(s), 10 queries , Gzip On, Redis On.
