查看: 2352|回复: 0
[供应] Wallys|DR6018C V01 |Qualcomm-Atheros IPQ6010|support DFS/QUECTEL RM500Q-GL/QC...
签到总天数:8天
签到总奖励:36金币
发表于 2023-3-9 09:22:11 | 显示全部楼层 |阅读模式
The IPQ6010 is built with advanced technologies that enable it to deliver lightning-fast speeds and robust connectivity. With a quad-core ARM Cortex-A53 processor and advanced Wi-Fi 6 capabilities, this chip can handle even the most demanding network traffic with ease. Whether you need to stream high-definition video, transfer large files, or connect multiple devices at once, the IPQ6010 has you covered.
One of the standout features of the IPQ6010 is its advanced QCA8075 Ethernet switch. This switch is specifically designed for high-performance networking, with features like packet prioritization, advanced security, and low-latency communication. Whether you're connecting a wired device directly to your network or using it as part of a larger switch fabric, the QCA8075 provides unparalleled performance and reliability.
Another key benefit of the IPQ6010 is its integrated support for the latest Wi-Fi 6 standards. With support for 802.11ax MU-MIMO, OFDMA, and 1024-QAM, this chip can deliver up to 4x faster speeds and up to 4x greater capacity compared to previous Wi-Fi standards. Whether you're streaming 4K video or connecting a dozen devices at once, the IPQ6010 provides reliable, high-speed connectivity with minimal lag or downtime.
In addition to its powerful performance capabilities, the IPQ6010 also includes advanced security features to protect your network from threats. With support for WPA3 encryption and other advanced security protocols, this chip provides peace of mind knowing that your network is secure and protected from unauthorized access.
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Symbol
Parameter
CPU
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
SFP Port
1x SFP port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetooth
CSR8811 BLE 4.2
Nor Flash
32MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
185mm x 116mm
Are you looking for a reliable and experienced partner to help you develop and produce wireless communication products? Look no further than Wallys Communications.
At Wallys, we specialize in the research and development, production, and OEM/ODM/JDM services of wireless communication products. Our team of skilled engineers has a proven track record in areas such as RF and embedded communications, network protocol, firmware, PCB design, and more. We use advanced equipment to ensure that our products are not only of the highest quality, but also meet the specific needs of our customers.
Whether you're in need of custom-designed wireless communication products, or looking to optimize existing ones, Wallys Communications has the expertise to help. Contact us today to learn more about our services and how we can help you achieve your wireless communication goals.
MAIL:sales3@wallystech.com
GMT+8, 2026-10-22 20:04 , Processed in 0.023202 second(s), 9 queries , Gzip On, Redis On.
