查看: 13513|回复: 0
[供应] Wallys/ DR6018-S Quad-core ARM 64bit A53 @1.8GHz Processor
签到总天数:8天
签到总奖励:36金币
发表于 2023-1-17 13:56:11 | 显示全部楼层 |阅读模式
Brief Introduce
DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
1GB DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
Wallys Communications (Suzhou ) Co., LTD  www.wallystech.com with over 15 years of experience in wireless industry, specialized in designing and manufacturing routerboards and wireless network cards. For decades, Wallys keep providing top wireless devices and wireless technology. We mainly develop high power wireless products based on Quacomm chip such asIPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ8072/IPQ8074/QCN9074 and so on. We sincerely hope to establish business relationship with your esteemed corporation.
Absolute Maximum Rating
Supply Voltage: 24V~48V(DC Jack)
Operating Temperature Range: -40ºC to +70ºC
Storage Temperature Range:45ºC to +105ºC
Operating Humidity Range:5% to +95% (non-condensing)
Hardware Specifications
CPU: Qualcomm-Atheros IPQ6010
CPU Frequency: Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory: 1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port: 1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot: M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot: 1x SD Card Slot(Option)
USB /header: 1x USB 3.0 Port(Option)
POE: 24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack: 24V~48V power supply
LED header: 2.0 pitch pin header
Serial Port: 1x Serial Port 4 Pin Connector
Wireless:
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Nor Flash: 8MB
Nand Flash:256 MB
DDR: 256-512 MB
Dimension: 125mm x 105mm x 20mm
GMT+8, 2026-10-22 20:03 , Processed in 0.028091 second(s), 11 queries , Gzip On, Redis On.
