查看: 14022|回复: 0
[供应] Wallys/ DR6018 Wi-Fi 6E QCN9074 WiFi 6E Card
签到总天数:8天
签到总奖励:36金币
发表于 2023-1-16 15:34:34 | 显示全部楼层 |阅读模式
Qualcomm-Atheros IP6010
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
32MB NOR Flash, 256MB NAND Flash
Support: Quectel RM500Q-GL
SupportCN9074 WiFi 6E Card
Absolute Maximum Rating:
Supply Voltage:        24V~48V
Operating Temperature Range:        -40ºC to +70ºC
Storage Temperature Range:        -45ºC to +105ºC
Operating Humidity Range:        5% to +95%  (non-condensing)
Hardware Specifications
CPU: Qualcomm-Atheros IPQ6010
CPU Frequencyuad-core ARM 64 bit A53 @1.8 GHz processor
System Memory:1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port:1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot:M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot:1x SD Card Slot
USB /header:1x USB 2.0 Port
POE:        24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack:24V power supply
LED Header:FFC/FPC Connector
Serial Port:1x Serial Port 4 Pin Connector
Wireless:
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetooth:Optional
Nor Flash:8-32MB(normally is 8MB)
Nand Flash:256MB
DDR:1GB
Dimension:185mm x 116mm
Wallys Communications(Suzhou). Ltd http://www.wallystech.com which is professional supplier specializing in manufacturing and offering superior OEM/ODM/JDM services in wireless communications. As a specialized manufacturer and exporter for these products in China, we sincerely hope to establish coorperations and business relations with your esteemed corporation. We mainly develop high power wireless products based on Quacomm chip such as IPQ6000/IPQ6010/IPQ4019/IPQ4029/IPQ8072/IPQ8074 and so on.
GMT+8, 2026-11-9 06:25 , Processed in 0.021139 second(s), 10 queries , Gzip On, Redis On.
